community projects
, join
GlobalTalk
, and have fun!
PentaxEnthusiast
Awesome, thanks! I just might have some small fans kicking around somewhere. Currently browsing ebay for a 1 GB memory kit as well...
Jan 28, 2026
videodoctor
You bet, @0dan0 ! Here's the output while recording, with the original stock D firmware: P1: SW:1 Num:6 H:1728 V:1296 LOFS:1728...
Jan 28, 2026
@videodoctor Can you call ipl getimepath 0 while recording?
Jan 28, 2026
Here is a thread on active cooling mods on an iMac G3.
Jan 28, 2026
PentaxEnthusiast
I would love to get some better cooling in the G3 and maybe push the envelope back to 700 MHz, but I'm also wondering if it makes more...
Jan 28, 2026
the 656x480 is the preview pipeline. On a Type C while recording: > ipl getimepath 0 P1: SW:1 Num:6 H:1600 V:1200 LOFS:1600 FMT:102...
Jan 28, 2026
videodoctor
Also, if I use the ipl setimepath command, I'm able to change the preview resolution to 320x240, and visibly changes the UI to show a...
Jan 28, 2026
Do you think the resistor you installed may be slowing things down too much when under load causing added heat resulting in the heatsink...
Jan 28, 2026
Arbystpossum
Re-creaming the G4 iMac heatsink and heat pipes, as well as letting the fan run at a higher speeds helped quite a bit, but I think the...
Jan 28, 2026
videodoctor
@0dan0, not sure I posted this before or we specifically discussed this, but this serial console command shows a 656x480 image size...
Jan 28, 2026
