videodoctor
@0dan0 , maybe I missed it in your notes but how did you update Qp in previous mods?
Feb 6, 2026
Has anyone run a 1080p or 1920x1200 panel in Portrait Mode under 9.2.2?
Hardware
MacPortrait appears to max out at ancient TPD resolutions. Is there a current solution? Windows and Ubuntu have had me spoiled for the...
Feb 6, 2026
B
Brutus75
Macintosh IIfx questions
The speaker worked great! Thanks.... now if I could only find some memory :)
Feb 6, 2026
Opening an oscillator can to determine cause of failure
FYI. On early Macintosh II motherboards, some engineer got overzealous with the ground loop. They connected pin 1 to pin 4/7 GND. I...
Feb 6, 2026
You can try a constant, but that will cause capture crashes with some film/grain.
Feb 5, 2026
videodoctor
Understood. I would like any insights you might have @0dan0 on adjustments to Qp---is that easy enough to swap out as a constant?
Feb 5, 2026
Macintosh Slice - a Pre-release Color Classic
A couple of things I forgot on my original post. 1. Someone added an FPU. That's nice. 2. But, they only added two 1 MB sticks of...
Feb 5, 2026
Just got lucky on eBay. The moment I saw no label I clicked 'Buy It Now'. The seller said "Wow, I just listed that."
Feb 5, 2026
Compact Macs
I just picked up a pre-release Color Classic. Notice that it is missing the word "Macintosh" beneath the Apple logo, the words "Color...
Feb 5, 2026
@videodoctor The RBN wouldn't be useful as a development base, as I just masking-out code to see what was causing capture the issues...
Feb 5, 2026
