Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
How to remove opencore from mac pro 5 .1
Please clarify if you are using OpenCore (Dortania mostly for hackintosh) or OCLP (OpenCore Legacy Patcher). If you built an installer...
Mar 4, 2026
Destroyer1976
Intel-based Macs
I have a mac pro 5.1. I had 'Mojave' installed on it. I attempted to use opencore to install 'Sequoia'. I totally messed up somehow. I...
Mar 4, 2026
I have a dead RAM slot on my 2004 15" PowerBook G4. How would I fix it?
How did you determine it was bad (swapped sodimms to opposite sides)? Are both sodimms identical (speed, size, etc)? Did you check...
Mar 4, 2026
notabitail
PowerPC G3, G4 & G5 (New World ROM)
Hi, I was given a PowerBook G4 15" 2004 last year, and I found out one of the RAM slots seems to be dead? How would I fix it? I have...
Mar 4, 2026
speakers
Be aware that the Beige G3 can boot only from partitions in the first 8GB of the IDE drive due firmware limitations. I've had good luck...
Mar 3, 2026
Analog board - display horizontal alignment
When was your green tube transplant? Do you have pics?
Mar 3, 2026
Imaging a Bootable Mac OS 9 CD the Hard Way
Was this image 2352/2048 times bigger than the partition created from disk2s1? If so, then it does contain all of the partitions. It's...
Mar 3, 2026
scj312
For my IDE machines I use standard SATA HDDs and SSDs with the StarTech IDE-SATA adapter.
Mar 3, 2026
I made some progress today. I was able to adjust config in settings to get srps beta Aquacenter to play clean and smooth playback from...
Mar 3, 2026
fishgee
"Matead" indicated in his post 485 in the original thread that "The chip is in fact a LSP5523-R8A." Digikey in the US has them for 77...
Mar 3, 2026
