Destroyer1976
How to remove opencore from mac pro 5 .1
Thanks for answering so soon. "OCLP (OpenCore Legacy Patcher)" is the one I was using. I originally had 'Mojave' installed, then I...
Mar 4, 2026
notabitail
I have a dead RAM slot on my 2004 15" PowerBook G4. How would I fix it?
As far as I could tell they are identical, yes. They look to be the ones that came with the machine (two 512MB ones). I looked and as...
Mar 4, 2026
Volvo242GT
Plans changed a bit. I downgraded to the A1278 MBP and am planning to sell the A1286 as a project machine for someone who has an A1286...
Mar 4, 2026
Please clarify if you are using OpenCore (Dortania mostly for hackintosh) or OCLP (OpenCore Legacy Patcher). If you built an installer...
Mar 4, 2026
Destroyer1976
Intel-based Macs
I have a mac pro 5.1. I had 'Mojave' installed on it. I attempted to use opencore to install 'Sequoia'. I totally messed up somehow. I...
Mar 4, 2026
How did you determine it was bad (swapped sodimms to opposite sides)? Are both sodimms identical (speed, size, etc)? Did you check...
Mar 4, 2026
notabitail
PowerPC G3, G4 & G5 (New World ROM)
Hi, I was given a PowerBook G4 15" 2004 last year, and I found out one of the RAM slots seems to be dead? How would I fix it? I have...
Mar 4, 2026
speakers
Be aware that the Beige G3 can boot only from partitions in the first 8GB of the IDE drive due firmware limitations. I've had good luck...
Mar 3, 2026
Analog board - display horizontal alignment
When was your green tube transplant? Do you have pics?
Mar 3, 2026
Imaging a Bootable Mac OS 9 CD the Hard Way
Was this image 2352/2048 times bigger than the partition created from disk2s1? If so, then it does contain all of the partitions. It's...
Mar 3, 2026
scj312
For my IDE machines I use standard SATA HDDs and SSDs with the StarTech IDE-SATA adapter.
Mar 3, 2026
