V
V.Yakob
AsantéFast 10/100 NuBus network card
I did some testing. The server was Power Mac G4 QuickSilver with an shared directory and a 10 MB "dummy" file Quadra 950 and built-in...
May 2, 2026
Speaking of software leading to performance improvement. I saw this recently and would like to explore/benchmark at some point...
May 2, 2026
wells
Macintosh Mini - (yet another) Maclock conversion project
Compact Macs
Hi yall, I was hoping to share during MARCHintosh but sharing now that I finally got things over the finish line. Similar to others...
May 2, 2026
T
On any of the X100 family, I strongly recommend installing Connectix's Speed Doubler. Apple had not made the 68K interpreter caching...
May 2, 2026
techknight
Plastic clutch
STL
May 2, 2026
techknight
Plastic clutch
Well I tried it, seems to work alright. Since this isnt an everyday machine I bet itll hold just fine.
May 2, 2026
Mark_W
SE/30 Reloaded no sound
I think those are jumper pads to bypass headphone detection in the 3.5mm jack: If you short them sound should be routed to the opamp...
May 2, 2026
MacOfAllTrades
Released — MacDoom for SE/30
Ok - same link as before (https://github.com/retrospectmike/MacDoomSE30/blob/main/DoomSE30.bin) It has an updated binary. Give it a...
May 2, 2026
T
ThePhage
Playback function from the scanner has been broken in the recent firmware mod efforts. It is documented in the user guide: As to the...
May 2, 2026
That is normal for the hacked firmware, playback is broken. To improve the image quality, more memory is used for capture, so on the...
May 2, 2026
MacOfAllTrades
I won’t jump to removing the xceed option yet — but you can test it both ways. I’ll add gamma and wht pt / blk pt correction to all...
May 2, 2026
K
KennyPowers
I would first try getting rid of the dedicated "Xceed/Bolle" option (go back to the 1.1.0 code), and then applying the gamma correction...
May 2, 2026
MacOfAllTrades
I think i have the right-sized fix and TLDR it’s the same net result you’re proposing — use the luminance calc i have in there now but...
May 2, 2026
