A
ArjenCNX
Thanks very much, well i have checked the other voltages, and they are all within spec, so that is good, ii trace down C-sync as well...
Jun 12, 2026
Mark_W
That's normal, unlike main power supply that has feedback control on the secondary, ctr power supply is regulated only on the primary...
Jun 12, 2026
A
ArjenCNX
So have 75V on the QL1, it is stable, oddly enough this is without the VGA mod in place, so it should be 60V or so. all other voltages...
Jun 12, 2026
The algorithm for Hammerhead is different than for Platinum. Platinum Bank Base registers support addresses with this mask: 0x7FE00000...
Jun 12, 2026
E
Eradicator
Ok, I did the lens swap/mod and I am on the firmwre "D" mod. But now I cannot zoom out enough to see the entire frame and sprocket...
Jun 12, 2026
Mark_W
If HOT is not shorted and CRT PSU does not enter protection mode after it tried to start initially, then the fault might not be in the...
Jun 12, 2026
A
ArjenCNX
okay now i have checked the board one more time, and i cannot see any errors there anymore, i did fix 2 connections before, now i have...
Jun 12, 2026
SPARCstation IPX power issues
This might be a question for @This Does Not Compute !
Jun 12, 2026
T
I wonder if this is an artifact of using the same ROM on both the PowerSurge and Catalyst machines. PowerSurge doesn't support...
Jun 12, 2026
ATTinyRTC: RTC Replacement for SE/30
Compact Macs
Many of you are already aware of Phil Greenland's Github project where he uses ATTiny85 to replace the RTC (Real Time Clock) on SE/30...
Jun 12, 2026
Maybe the hardware allows it. I don't think the ROM HWInit memory detection routines for Platinum might not. I've attached startup...
Jun 12, 2026
