A
ArjenCNX
Also, i had the idea to integrate HDMI out at some point, im looking for suitable IC's for that that can take the RGB+sync signal and...
Today at 2:24 AM
A
ArjenCNX
yeah man! so, indeed CL26 will be added, probably around 3nF, vertical image size right now is barely adjustable so ill find the cause...
Today at 2:21 AM
macoslove
Macintosh LC III Bodge-Laden PCB
Ah good to know! I guess there were more than just the bodge mistakes with this guy!
Today at 2:06 AM
Nice job. C22 is reversed. That is, although you installed it in the way Apple marked it, Apple made a mistake. You need to flip it the...
Today at 1:54 AM
Portable Misc - Hinge clip fix, Earlier features, Super Static memory
What specific part number of Gorilla epoxy did you use? And, have you tested how strong the bond is to polycarbonate? I used DCM to...
Today at 1:37 AM
macoslove
Well, here's to the next step! No destruction found from the fishy caps and for that I am thankful.
Today at 1:21 AM
Macintosh Portable
Broken Corners I've seen enough broken cases that I lean toward being pragmatic rather than attempting a pristine repair. A common...
Yesterday at 11:44 PM
Correct. Those are factory.
Yesterday at 11:18 PM
macoslove
Macintosh LC & Performa
I am not sure about these bodge wires but I assume they are first revision last minute fixes, or at least that is the hope. No chime or...
Yesterday at 10:50 PM
RetroViator
InventoryDifferent - Managing your vintage device collection
I wanted to jump back on this thread to say I got this up and running on a Raspberry Pi 5 which is also hosting my RetroNAS setup. I'm...
Yesterday at 10:11 PM
