macoslove
Macintosh LC III Bodge-Laden PCB
I am glad it was caught! It now lives again! Gotta love it!
Jun 15, 2026
speakers
I got caught by this a few years back. It's a decoupling capacitor on the -5V rail. The original aluminum cap didn't care but if you...
Jun 15, 2026
A
ArjenCNX
Also, i had the idea to integrate HDMI out at some point, im looking for suitable IC's for that that can take the RGB+sync signal and...
Jun 15, 2026
A
ArjenCNX
yeah man! so, indeed CL26 will be added, probably around 3nF, vertical image size right now is barely adjustable so ill find the cause...
Jun 15, 2026
macoslove
Ah good to know! I guess there were more than just the bodge mistakes with this guy!
Jun 15, 2026
Nice job. C22 is reversed. That is, although you installed it in the way Apple marked it, Apple made a mistake. You need to flip it the...
Jun 15, 2026
Portable Misc - Hinge clip fix, Earlier features, Super Static memory
What specific part number of Gorilla epoxy did you use? And, have you tested how strong the bond is to polycarbonate? I used DCM to...
Jun 15, 2026
macoslove
Well, here's to the next step! No destruction found from the fishy caps and for that I am thankful.
Jun 15, 2026
Macintosh Portable
Broken Corners I've seen enough broken cases that I lean toward being pragmatic rather than attempting a pristine repair. A common...
Jun 14, 2026
Correct. Those are factory.
Jun 14, 2026
macoslove
Macintosh LC & Performa
I am not sure about these bodge wires but I assume they are first revision last minute fixes, or at least that is the hope. No chime or...
Jun 14, 2026
