meggatron
Did you end up trying out the D version? Just ordered a unit off Amazon, similar serial number: J2925148BK01099. From what I can tell...
Jul 25, 2026
campbellashe
Expansion Memory Cards and Speed Limitations above 5MB on the Macintosh Portable
I did confirm that a poke of $FC0200 after sleep does improve speed from 22% to 51% on Snooper speed test consistently. Before sleep...
Jul 25, 2026
campbellashe
Here is the SpeedTest app on Github: https://github.com/2tf2294x4g-maker/MacintoshPortableDTACKSpeedTest Not the best programmer and...
Jul 25, 2026
campbellashe
8MB RAM Card — Speed Testing Results and Analysis Following up on my earlier question about the slowdown with more than 5MB of RAM...
Jul 25, 2026
croissantking
Horizontal lines on SE/30 Display
I thought it was fairy common - I’ve seen various people mention it. In my case I’ve sometimes seen the issue appear but not...
Jul 25, 2026
mmaseda
Glad to know someone else has seen this. It’s something that if you’re not looking for you might not notice. One thing I might try...
Jul 25, 2026
croissantking
I have seen this issue on my SE/30s with Sony PSU.
Jul 25, 2026
N
NJRoadfan
Adapting a IIGS m6014 for other uses (SNES)
Out of desperation, I managed to hook up an Amiga to mine.... at least until I got the right adapter to use my other monitors with the...
Jul 25, 2026
N
NJRoadfan
Spatulas from Europe
I guess they didn't have any in stock locally. ☹️
Jul 25, 2026
@SuperSVGA is the expert on this. He stated "Any access at all is sufficient, such as a simple tst.w $FC0200 instruction or running DM...
Jul 25, 2026
campbellashe
David, I've got my 8 MB card working. Seeing slow down a boot with the 8MB setup. Do you understand the reason for the slow down. I 'm...
Jul 25, 2026
