fishgee
If you can only get the top or bottom of the image in focus, it would seem to me that your camera wasn't re-mounted precisely parallel...
Aug 14, 2026
D
danhendleydigital
I've been using the latest version a lot recently and the freezing issue is completely solved. The only problem I'm running into is that...
Aug 14, 2026
S
sheppy1
SE30 Video Issues
Jut to close this off and in case anyone has the same issue in future. The problem was UG8 and the chip I'd used to replace it. I'd gone...
Aug 14, 2026
PL212
BlueSCSI Toolbox - NeXT Edition
Wow, was not expecting that level of polish! I don't know your comfort level with sharing the source code, but i'd be glad to try and...
Aug 14, 2026
Have a FAT build for 68k,x86,SPARC that works on 4.2 - I'm going to guess 3.3 will need a lot different GUI/WM calls.... Obviously some...
Aug 14, 2026
Froggy814
You are soooo right... This is now something I will let the experts do, instead of soldering the pi together and designing that myself...
Aug 14, 2026
Scott
OK, what hardware do you have it on? I can tell it's System 7.5 from the menu bar. I have never tested Midnight Rescue under System...
Aug 14, 2026
No, we have this part. We need the full register dump. Thank you for trying it, though - proves it's not just my hardware, but what ROM...
Aug 14, 2026
Mr. Macintosh
Done, sorry should have added that context. 👍
Aug 13, 2026
E-Machines Big Picture Card w/Mac SE Interconnect - Cloning Possibilities?
Hardware
Pulled this Card/Adapter out of storage to see if it might be a cloning target. Found my old thread about this one over at the MLA...
Aug 13, 2026
Can you insert some quotes from previous posts to remind us what this is about? EDIT your post, click the [ ] button to toggle off BB...
Aug 13, 2026
Mr. Macintosh
@ClassicHasClass @joevt @Rairii Is this the data you were looking for the Windows NT register dump? VENEER is loaded at: image_base =...
Aug 13, 2026
techknight
No, when you lay out an RP2350 or likewise design, you have to follow the layout guidelines exactly to a T, or your DC converter doesn't...
Aug 13, 2026
