Balto1986
i've been trying the adjusting/shimmering the camera, but with no luck so far. but Im gonna try a little more. I dont use the plastic...
Aug 14, 2026
Froggy814
I have! It's a little big because it is 4:3, so a 16:9 will fit better and look more original in the Portable. The original screen is...
Aug 14, 2026
V
VeryVon
Agree. On the SE/30 it sounds good and the same on system 6 & 7. You said you have some LC/LCII machines where it plays correctly...
Aug 14, 2026
Scott
Yes, this is the issue. If you have access to another LC or to a Plus, SE, or Classic, note the difference. This is not what that music...
Aug 14, 2026
V
VeryVon
Sure, here's what it sounds like on the LCII in System 6.0.8, on internal and external speaker. I can hear what you're talking about...
Aug 14, 2026
360alaska
Neat! Have you considered using an Ipad screen?
Aug 14, 2026
fishgee
If you can only get the top or bottom of the image in focus, it would seem to me that your camera wasn't re-mounted precisely parallel...
Aug 14, 2026
D
danhendleydigital
I've been using the latest version a lot recently and the freezing issue is completely solved. The only problem I'm running into is that...
Aug 14, 2026
S
sheppy1
SE30 Video Issues
Jut to close this off and in case anyone has the same issue in future. The problem was UG8 and the chip I'd used to replace it. I'd gone...
Aug 14, 2026
