Some USB serial port adapters serial port wiring examples at...
Aug 17, 2026
Weird discoloration on Color Classic CRT
So, I'm not sure if my Color Classic degauss coil / circuit is bad, or if the magnetic disruption was simply too much for it, but...
Aug 17, 2026
S
surfer150
84V Mod on Color Classic - Thick light gray bars
I did the beefy component upgrade today. Beside of replacing the parts JDW recommends to replace, I used the opportunity to replace a...
Aug 17, 2026
Yikes! Im glad it is up and running and working well for you after all of that :)
Aug 17, 2026
B
brain
NEXT Cube Needs TLC
It did not. I helped someone with some HW work on another classic system at no charge as a favor, but they insisted I take this cube in...
Aug 17, 2026
Mark_W
Yeah it's kinda tricky to do it with analog board installed, what I did is measure voltage, pull analog board out, make very small...
Aug 17, 2026
cc333
Yup. I think part of what threw it all off was the fact that coincidentally, either the motherboard or PSU (probably both) failed as I...
Aug 17, 2026
S
sheppy1
SE30 Horizontal Lines 64MB RAM
Compact Macs
Hello I’ve an issue with an SE30 I’ve been fixing for a few weeks now and I cannot crack it. So this machine had zero signs of...
Aug 17, 2026
S
surfer150
PP1 is not glued on my revision B board, but how to adjust it when the tube is just above the trimmer? I can’t get to it without the...
Aug 17, 2026
Mark_W
Agree with what @jonschultz said before regarding B2 voltage. Also first thing you need to do before adjusting geometry is to adjust the...
Aug 17, 2026
