D
Dhardrian
Card Retainer Baffle - PM 7600 / G3 - photo request
I was able to load the Right side of the G3 file into Prusa Slicer and Fusion360, however the left side seems to have major issues...
Tuesday at 1:29 AM
Some USB serial port adapters serial port wiring examples at...
Monday at 11:46 PM
Weird discoloration on Color Classic CRT
So, I'm not sure if my Color Classic degauss coil / circuit is bad, or if the magnetic disruption was simply too much for it, but...
Monday at 11:20 PM
S
surfer150
84V Mod on Color Classic - Thick light gray bars
I did the beefy component upgrade today. Beside of replacing the parts JDW recommends to replace, I used the opportunity to replace a...
Monday at 11:19 PM
Yikes! Im glad it is up and running and working well for you after all of that :)
Monday at 9:52 PM
B
brain
NEXT Cube Needs TLC
It did not. I helped someone with some HW work on another classic system at no charge as a favor, but they insisted I take this cube in...
Monday at 7:54 PM
Mark_W
Yeah it's kinda tricky to do it with analog board installed, what I did is measure voltage, pull analog board out, make very small...
Monday at 7:11 PM
cc333
Yup. I think part of what threw it all off was the fact that coincidentally, either the motherboard or PSU (probably both) failed as I...
Monday at 7:04 PM
S
sheppy1
SE30 Horizontal Lines 64MB RAM
Compact Macs
Hello I’ve an issue with an SE30 I’ve been fixing for a few weeks now and I cannot crack it. So this machine had zero signs of...
Monday at 7:03 PM
