  • David Cook
    I saw this really crisp-looking Macintosh IIx on eBay. It has the least yellowing of any case from that era that I have ever seen...
  • Scott
    That's what I am using in my lab--with a slight catch. I actually run 6.0.7 on them. I know Apple says 6.0.7 shouldn't be used on an LC...
  • Garth Beagle
    I can't see it actually stated anywhere (but I can't believe you've not tried it) but I assume you've hit the power button? It's normal...
  • fogWraith
    fogWraith replied to the thread Hotline!.
    It's possible to browse the contents of a server via the API, but it doesn't involve any file transfers. I guess it would be possible to...
  • nilobject
    nilobject replied to the thread Hotline!.
    i've got a web file browser in the works. it can view zip and sit cpt contents without unarchiving, and resource forks. adding a hotline...
  • JDW
    High Resolution Top & Bottom photos of all the DC boards. Barrel Plug Board Primary DC Board with Daughtercard Attached Daughtercard
  • fogWraith
    No web client interface (yet), it could be done "the old fashioned way" by using the current server API though - more or less. There is...
  • JDW
    Here are photos of the insides of the Newer Technology Nupower PRAM battery (for PB G3 Wallstreet) that is now dead, and which I...
  • JDW
    This video shows the two DC boards, showing how there is nothing wrong with the solder joints at the barrel plug, and showing the...
  • JDW
    Here's a video showing how I removed the PRAM battery (just FYI)...
  • JDW
    I have two PowerBook Wallstreet PDQ notebooks that once worked fine several years ago), but now neither will power-on when I press the...
