Where is there a PMU "reset button" on the "PDQ"? (Mine is indeed a "Wallstreet" in that it is 2nd gen., but technically it is "PDQ")...
Aug 28, 2026
Apple Lisa 3d Case Project
It is a major limitation for people like myself who mostly have Apple keyboards, all of which (USB models) have hubs. But beyond that...
Aug 28, 2026
thecloud
My Wallstreet PowerBook G3 died in a similar way. It also had a long-dead (or mostly dead) battery, and so I always relied on powering...
Aug 28, 2026
Radius FPD/SE - Rotation Transform/HDMI Output via FPGA Project Board - CLAUDE SESSIONS
Couldn't have explained this better mysel . . . that way at all! :ROFLMAO: Hope this makes sense to the gang here. Claude figured...
Aug 28, 2026
I found the ideal way to measure the voltage output... But I too am not getting any chime or video, and yet you say your experience...
Aug 28, 2026
Garth Beagle
Also these same PSUs can be used with other PowerBooks (IIRC at least 2400, 3400, original iBook) so if by chance you have one of those...
Aug 28, 2026
# Scanline Rotation Transform — Engineering Spec ## 0. Project Context: Cloning the 1986 Radius FPD (64/68Hz Board) This project...
Aug 28, 2026
Hardware
I'll edit in the other threads leading to this at some point. It's a Cloning Project of the 1086 first gen 64/68Hz version of Radius/SE...
Aug 28, 2026
Garth Beagle
You can safely test the power adapter voltage by using a bit of heat shrink tubing around the center pin in its connector so that it...
Aug 28, 2026
Here are photos of my power adapter (I have two):
Aug 28, 2026
Well, I tried putting something together today that involved a usb-c breakout board type device, some resistors and a capacitor to try...
Aug 28, 2026
