V
V.Yakob
What did you cook today?
A couple of days ago I went out to cook outside again -- just vegetables from the garden with meat in a cauldron on the fire. Despite...
Aug 28, 2026
One person on FaceBook is giving me feedback, and I just tried two different methods, although both have the same bad result... METHOD...
Aug 28, 2026
Macintosh IIx - Manufactured Feb 1991. What??
CR-45S. So, it's loud. 😞
Aug 28, 2026
That occurred to me as well. Even if Apple announced discontinuation for consumers, I imagine they would fulfill contracts that went...
Aug 28, 2026
Yes, and that keyboard sequence is on the back of the computer too. I've tried it without success multiple times. Here are high...
Aug 28, 2026
Apple Lisa 3d Case Project
Sounds like a sound approach! :) I just stuck that supply board up there if you wanted to check it out. Are you considering using a...
Aug 28, 2026
thecloud
On the PDQ it's a key sequence rather than a button. I found an article that mentions the PMU reset is holding down Fn-Ctrl-Shift-Power...
Aug 28, 2026
Where is there a PMU "reset button" on the "PDQ"? (Mine is indeed a "Wallstreet" in that it is 2nd gen., but technically it is "PDQ")...
Aug 28, 2026
It is a major limitation for people like myself who mostly have Apple keyboards, all of which (USB models) have hubs. But beyond that...
Aug 28, 2026
thecloud
My Wallstreet PowerBook G3 died in a similar way. It also had a long-dead (or mostly dead) battery, and so I always relied on powering...
Aug 28, 2026
Radius FPD/SE - Rotation Transform/HDMI Output via FPGA Project Board - CLAUDE SESSIONS
Couldn't have explained this better mysel . . . that way at all! :ROFLMAO: Hope this makes sense to the gang here. Claude figured...
Aug 28, 2026
I found the ideal way to measure the voltage output... But I too am not getting any chime or video, and yet you say your experience...
Aug 28, 2026
Garth Beagle
Also these same PSUs can be used with other PowerBooks (IIRC at least 2400, 3400, original iBook) so if by chance you have one of those...
Aug 28, 2026
