geordiepingu
Walkthrough - Replacing the Optical Drive in a G4 Cube
Hi, not to hijack a thread, I thought I would add my experience in case it helps anyone else - I had a load of bother retrofitting a...
Aug 28, 2026
Balto1986
Thanks alot, I got it working 😁 I had to use alot of force and there was some shavings I had to remove after. It was also really tricky...
Aug 28, 2026
jasa1063
Hercules InColor Card complete with box and manuals
I have been looking for a Hercules InColor Card for the several years now. They don't come up too often, but I found this one on eBay...
Aug 28, 2026
V
V.Yakob
What did you cook today?
A couple of days ago I went out to cook outside again -- just vegetables from the garden with meat in a cauldron on the fire. Despite...
Aug 28, 2026
One person on FaceBook is giving me feedback, and I just tried two different methods, although both have the same bad result... METHOD...
Aug 28, 2026
Macintosh IIx - Manufactured Feb 1991. What??
CR-45S. So, it's loud. 😞
Aug 28, 2026
That occurred to me as well. Even if Apple announced discontinuation for consumers, I imagine they would fulfill contracts that went...
Aug 28, 2026
Yes, and that keyboard sequence is on the back of the computer too. I've tried it without success multiple times. Here are high...
Aug 28, 2026
Apple Lisa 3d Case Project
Sounds like a sound approach! :) I just stuck that supply board up there if you wanted to check it out. Are you considering using a...
Aug 28, 2026
thecloud
On the PDQ it's a key sequence rather than a button. I found an article that mentions the PMU reset is holding down Fn-Ctrl-Shift-Power...
Aug 28, 2026
