jmacz
Macintosh IIfx Project
The capacitors need to be replaced. Even if they appear fine, you’ll know when you remove them because you’ll smell the fishy odor...
Oct 1, 2026
nilobject
I resurrected an old Hotline client
@fogWraith is currently developing hotline software: https://tinkerdifferent.com/threads/hotline.5302/ and @Knezzen updated hotstuff in...
Oct 1, 2026
jonschultz
Excellent suggestions regarding the voltages to check. I was also going to mention that checking a flyback-generated voltage would be a...
Oct 1, 2026
Ron's Computer Videos
Running the Macintosh II High Resolution Video Card at 512x384?
No, because then you would get a “OUT OF RANGE” message (like I noted above), not a 640x480 signal. But I 100% get what you're saying...
Oct 1, 2026
Mark_W
The screen geometry and color are both way off which is a good hint that something's wrong with secondary voltage outputs from CRT...
Oct 1, 2026
It's been almost a month since my last post, so I want to provide an update so as to hear your kind thoughts. ONE PDQ NOW POWERS ON...
Oct 1, 2026
jonschwenn
Never used Pippin - Battery removal
Pippin
I've had some interest in the Pippin since I first saw one, which was the same day I learned of its existence. I don't recall it ever...
Oct 1, 2026
