S. Pupp
If not done already, I would evaluate for barrel plug PCB failure by exchanging the barrel plug PCB's between the two PDQ's: - If the...
Oct 2, 2026
Mark_W
DL21/22 voltage is ok, but DF2 voltage is much higher than it should be (8.2V). Did you install the correct zener diode? Also double...
Oct 2, 2026
melw
Hi @Boojakascha - that sounds really unfortunate! Just to be sure I've got the details right: You modded the camera in the unit and...
Oct 2, 2026
B
Boojakascha
The problem first appeared while running a melw Type D firmware and since then I reflashed to a more current melw firmware. I have not...
Oct 2, 2026
D
Doctorkillbydeath87
Thank you so much, I was able to spend a little bit of time tonight trying out these suggestions. I'm not overly familiar with reading...
Oct 2, 2026
NuCF — Super Fast PDS-slot Hard Drive by ZZJ
I cannot speak on behalf of the creator, @zigzagjoe , but my guess is No, based on the fact he only specifically mentioned the SE/30...
Oct 2, 2026
Nixontheknight
Will it work with a Centris 650?
Oct 2, 2026
InsufficientPostage
Maceffects transparent ADB mouse button extremely stiff.
Yeah absolutely. I understand that the cost of two injection molding dies would probably be prohibitive. It’s a bummer to hear that it...
Oct 2, 2026
I own a MacEffects clear mouse too and found it too stiff for me as well, but that is by design. Mark J. (owner of MacEffects) told...
Oct 2, 2026
I recently purchased the latest creation by @zigzagjoe called NuCF. Here's his sales thread offering all the details. It's faster...
Oct 2, 2026
Running the Macintosh II High Resolution Video Card at 512x384?
It's the regular, non GC, "Macintosh Display Card 8•24" card. Just tested working in my Quadra 700 with a Macintosh 12-inch RGB Display...
Oct 2, 2026
