JohnCT
Back in the early 2000s, a lot of flat TV main boards used a SOT23 - 3 pin reset IC that would activate whenever the main board...
Oct 2, 2026
T-Man
Last Apple CRT, restore,antireflective coating
I haven't been able to figure this one out yet.This monitor was last powered up about 2 years ago, so I was going to disassemble, wash...
Oct 2, 2026
B
Boojakascha
Indeed, just after the hardware mod. The firmware ran fine =) Thank you very much for the tips, I will work through them and...
Oct 2, 2026
T-Man
eMac swivel Base
Maybe just a solid heavy wide wooden base and a nice finish with the hardware to use the 3d print.....kinda miss the clear then though
Oct 2, 2026
Okay, dumb question has anyone cloned the 128k Logic Board yet?
Found it! Mini-ITX sized Macintosh Plus...
Oct 2, 2026
May be a tangential rabbit hole, consider the source, Wikipedia(ick) says IWM is a condensed version of D][IC. So wondering cloning IWM...
Oct 2, 2026
K
Knife Cult
Schematics would help, but a problem that fixes itself as you described sounds like a bad cap. Is this the board in question: I think...
Oct 2, 2026
D
drzeissler
Disk Jockey, a disk image file maker for your retro stuff - Beta for version 3!
What is MECC.1/2 ?
Oct 2, 2026
