T-Man
Distorted Image with AppleColor High-Resolution RGB Monitor
have one of these monitors and along the edges the text/images were out of focus….when you look at Apple advertisements from the time...
Oct 5, 2026
goon
MiST emulator
Other
Hi, I want to try a MiST system emulator for use with a full MiST Amiga configuration SD disk. Source code is here ...
Oct 5, 2026
NuCF — Super Fast PDS-slot Hard Drive by ZZJ
QuickBench graphs below compare performance of NuCF to MacSD in my SE/30 with 50MHz CPU-socketed Daystar PowerCache. Interestingly...
Oct 5, 2026
If by "PSU" you mean the "external AC Adapter," then as I mentioned in my earlier posts, I purchased a brand new, modern power brick...
Oct 5, 2026
Could it be a failing PSU that takes a while to get warm and fail? Just measuring the voltage output without load does not always...
Oct 5, 2026
3D printed 2.5" HD bracket for CF2IDE
What is the complete list of compatible PowerBooks? I myself have a Wallstreet PDQ. When I used this mSATA-to-IDE adapter with this...
Oct 5, 2026
I left the machine connected to the AC Adapter over the weekend. (The "good" one, not the one that never powers on.) It booted up right...
Oct 5, 2026
mmu_man
Poor eMate needs fixing
I got distracted because… because people :mad: Today I cleaned up the bottom case on Dave's stream: Still needs a lot of work, but I...
Oct 5, 2026
Apple Lisa 3d Case Project
@KnobsNSwitches , I'd also be willing to print one and ship it to you at cost, assuming you aren't using this to justify said purchase...
Oct 4, 2026
Sure, just hook up to the two expansion pins (S1/S2) and source 3.3v/gnd from somewhere on the pico.
Oct 4, 2026
