mmu_man
Poor eMate needs fixing
Turns out there's a cut trace on the membrane. I tried conductive ink but it didn't work, I'll see tomorrow if it just needed to dry out.
Oct 9, 2026
BajaTym
PowerBook 180c -- Vertical White Column Lines
Just a little rant... I have to say, IMO, desoldering old capacitors is pain. After pulling the first one, I discovered a bit of...
Oct 9, 2026
XodiumLabs
Harman/Kardon Soundsticks subwoofer potentiometer?
That looks about as close to drop in as I’m going to get, heh. I’ll measure up mine but this looks like the closest fit. Thankfully...
Oct 9, 2026
This Does Not Compute
This one might work, I'd check the datasheet to confirm the dimensions...
Oct 8, 2026
mmu_man
Let's reassemble the keyboard on that #eMate ! https://youtube.com/live/y6ntLRxJCCk
Oct 8, 2026
R
RMConverter
FIRST TOPIC - Response to Question on BIOS The original version said 2.0. I am attaching a photo. I loaded the version "B" from the...
Oct 8, 2026
XodiumLabs
PowerPC G3, G4 & G5 (New World ROM)
I know this is probably more of an audio equipment thing than a Mac thing, but these are the ones that go with my Cube (with USB audio...
Oct 8, 2026
DW1992
CodeWarrior
SquirrelEDIT, the 1Bit pixel editor for C developers
Just a little update... I'm taking a little break from SquirrelEDIT's development (I'm pretty happy with where it's at, and where it's...
Oct 8, 2026
JohnCT
Same - my reflash also says "Type D- WIP" but it's otherwise identical to the original firmware. I just tried the file in #731 and...
Oct 8, 2026
lrdgreen89
First-time flash, D-type. I flashed the FW from post #734. The first screen said "Type D - WIP," but everything else looks no different...
Oct 8, 2026
