S
stepleton
Apple Lisa 3d Case Project
It's not your fault, it's almost certainly a side-effect of one of Alex's changes to the main LisaFPGA code. His change revealed a bug...
Oct 9, 2026
melw
Hacking the Reflecta DigitDia Evolution (Novatek NT96660) Slide Scanner
Hardware
Hello all! After the Kodak Reels tinkering I got back to my other digitizing device: a Reflecta DigitDia Evolution magazine slide...
Oct 9, 2026
I've been pressing the darned Power key every freaking day and finally today the "semi-good" PDQ booted. I was able to booted from an...
Oct 9, 2026
I've not flashed or watching any videos about flashing yet. But I take it there's no way to easily re-flash it while inside the case?
Oct 9, 2026
ried
Options for hard drive replacement
The internal Widget hard drive can be replaced with: X/ProFile by SigmaSevenSystems, sold by VintageMicros (currently being...
Oct 9, 2026
melw
Videos saved with custom firmware are using higher bitrate than the stock firmware. Built-in playback likely can't handle this. 64GB...
Oct 9, 2026
melw
Type D — FW 271: build number on the start-up screen Firmware version added to start-up screen ("Type-D - FW 271") No other changes...
Oct 9, 2026
melw
Ok, that's another report on the same topic. Let me share a new build that prints the firmware version also in the splash screen to be...
Oct 9, 2026
jonschultz
Mystic Color Classic Screen Distortion
Yeah, the bulging is bad and a fairly typical problem on Color Classic analog boards, precisely because of the heat generated by those...
Oct 9, 2026
nilobject
#ev3
ported using the Aeorofoil source
Oct 9, 2026
melw
Thanks for reporting! On my unit, "FW 270" in yellow at the top right is visible all the time, so if nothing appeared at all, I'd like...
Oct 9, 2026
christcc2
Next question. Should the 3300uf 16V look like it’s bulging at the top, and thoughts on these two diodes that look burnt underneath?
Oct 9, 2026
One thing I need to check on. Got some reason, I now get a message on power-up about the "Built in parallel port: unconfigured". I...
Oct 9, 2026
JohnCT
As far as I know, the camera itself is fine, but the optics are the biggest bottlneck. There are people who replace the lens to gain...
Oct 9, 2026
