Can Mac OS 8.1 run on a SE/30? RASCSI/BlueSCSI image wanted
1,899
I'm pretty sure @DosFox1 on twitter has these (if you dont have the twitters I can DM him and point him to this thread)
Curious, but how slow is it, and is there any reason to run 8.1 on it, other than because you can? 😂
GiGaBiTe
34
29
I've had 8.1 on my overclocked LC III, and my stock Performa 600. In both cases, it was painfully slow. Not sure how its usable on a SE/30 with a 68030 at half the speed of either of those machines.
I don't see the benefit either, you actually lose support for older applications and drivers when going to 7.6x or above due to the removal of 24 bit addressing compatibility.
pfuentes69
380
297
I used the image mentioned above and it worked nicely
That image worths of deeply checking… it’s full of goodies! 👍
pax
That, and 8.1 can read HFS+ disks. So an 8.1 partition to boot into if you want to access an external HFS+ SCSI disk is nice.
Reactions: Patrick
LongAlphabet
19
This is great, thanks! I've downloaded the file (thanks for creating this) - will be picking up a BlueSCSI in a week or so. I already have the ROMinator II chip.
Question 1: What is an .hda file? While i'm familiar with .img and .sit and .zip suffiixes, what is ".hda"? The file I've downloaded and opened (on Mac OS 10.15 machine) is titled "HD10_512 Macintosh HD Sys 81.hda". When I get the BlueSCSI, so I just drop this .hda file onto the SD card, and then pop it into my 68K host machine?
Question 2: How do I open/access this .hda (to move files I want on the 68K mac) while using my modern mac? Thanks!
Hi @LongAlphabet! :)👋
Awesome! :cool:(y)
The .hda is a type of a binary file created by certain software. For BlueSCSI, it is a hard drive image file that is read by BlueSCSI and mounted to the host computer's operating system.
Yes, that is correct. BlueSCSI uses a naming scheme that identifies some important things as it emulates the hard disk image file as a physical Quantum Fireball hard drive on the Mac. :geek:
According to this guide using BlueSCSI as written by @eric:
HDxy_512.hda
HD - Hard Disk
x - SCSI ID to attach to. 0-7 (though 7 on a Macintosh is the System)
y - LUN ID - Always set to 0.
512 - Sector size. Set to 512 if unsure. 256, 512, & 1024 supported.
In this hard disk image file's name "HD10_512 Macintosh HD Sys 81.hda," the first digit means SCSI ID 1. The second digit is the LUN ID 0 and always zero. The 512 is the sector size. Generally, 512 is the norm.
Use a Mac emulator, such as Basilisk for emulating 68k Macs. :D
Reactions: LongAlphabet
LongAlphabet
19
Thanks for explaining the guide @retr01 - that helps tremeandously! Can't wait to get the target machine up and running on BlueSCSI, and soon, Mac OS 8.1!
LongAlphabet
19
@retr01 I've got a few machines - let me list the machines and the goals. The SE/30 A is a unique machine - it's the one I want to soup up and get running Mac OS 8.1 - just because I can! I have a TinkderDifferent member to thank for saving it - there's a short post about it actually! I've got a 128GB SD card that I could use for this...
The Classic II is a special computer - my parents bought as my family computer back in the day - I've managed to save the data from the external hard drive entirely, and, want to set it up again as, it was, so that it's a "nostalgic" time capsule. It's had it's logic board recapped by @Drake too!
Lastly, i've also got a Mac Plus that I'd love to use a DB25 BlueSCSI to have fun with, and, a IIci that I could use an Internal BlueSCSI inside. Also, be great to use as a way to move files between computers.
Core Computers I want to get BlueSCSI into:
  1. SE/30 - (DayStar 50mhz 030 Upgrade Card + RominatorII ROM) - Goal: get an Internal BlueSCSI running Mac OS 8.1 (will need 128MB RAM First)
  2. Classic II (10MB RAM + FPU) - Goal: get an Internal BlueSCSI and have it running exactly as it was as a family computer back in 1997 (I have the files backed up on Zip disks - OS is likely 7.1 or 7.5)
  3. Mac Plus (4MB Ram) - Goal: get an external DB25 BlueSCSI and use the Mac Plus "Mac Pack" 1000 Games and Apps to have it running for nostalic reasons (great for LocalTalk games, Bolo)
  4. IIci - (10MB Ram) - Goal: get an Internal BlueSCSI and have it up and running a version of system 7 (and more RAM later)
