I picked up a Gefen ADC switch recently, sans power supply.  It takes 4 DVI inputs (as well as USB, and audio) and outputs DVI / USB, and audio, as well as all those things over an ADC connector.
So, my goal is to hook up all my towers, including my Intel PowerMac, via DVI to the switch, and have them all share my 22" Cinema LCD. I don't believe it will run send output to my 17 CRT ADC monitor, as that expects an analog signal and I'm pretty sure this switch simply passes along the DVI's digital signal. I know Gefen made a VGI / ADC adapter that might actually work with the CRT, as long as you swap out the power supply for something beefier.
Anyway, my question is, does anyone know the connector type for this power supply, and does anyone know pins need 24v power?
At the end of the day, I may just pick up this, as I would guess it will work with my switch, despite being meant to a different model: https://www.ebay.com/itm/3723211874...OlYrriC72/AqwVduLmhCgooVHSLe|tkp:BFBMoNK7_tJg
