6100/66 DOS Compatible
KennyPowers
351
384
Finally got this thing 100% done!
  • full recap of the PSU and logic board
  • replaced HD with a BlueSCSI
  • new thermal paste on both CPUs
  • added a slim, quiet 80mm fan behind the inlet vents
  • 264MB RAM on the Mac side
  • 32MB RAM on the PC side (PC wouldn't boot with a 64MB EDO SIMM installed :rolleyes:)
  • OS 8.6 / Windows 95 on top of DOS 6.22
  • thorough cleaning and retrobrite...looks brand new!
I'm going to rearrange some stuff on my desk to give it a permanent home, but here she is performing her DOS gaming duties admirably:
Byte Knight
146
129
Looks fantastic - nice job with the restoration! I had a plain-Jane 6100 back in the day and it was great machine for playing Marathon over LAN.
KennyPowers
351
384
I remember playing 2-player DOS Doom over serial cable to an actual PC with mine when I was a kid.
Patrick
435
I have a 6100 with a dos card. But i think the 6100 needs to be recap'd because the cd audio doesn't work. Which means the soundblaster on the dos card doesn't produce sound. It took some troubleshooting to figure that out, because the mac DOES beep. but won't play audio on cd nor will the dos side have sound.
KennyPowers
351
384
Now I kinda wanna play with my CP/M Apple II card. Kind of a similar idea I guess...platform compatibility by just slapping a native CPU on a card :)
I've got this new-in-box one for the IIc too, but my IIc's still need fixing up:
Patrick
435
i don't know if its true. but i've heard that that card was at one time the most popular CPM computer. Like out of all the CPM machines you could buy at the time. the card for the apple II one sold the most.
I find these kinda .. computer on a card .. type things interesting.
KennyPowers
351
384
Upgraded my 6100 with a GUIDED MISSILE :ROFLMAO:. Grabbed this (hilariously marketed) slot blower fan for $2 at VCFMW to see if it fit under the 6100's HD bay. After removing the slot bracket, it's snug, but it fits perfectly:
PXL_20231031_131616343.jpg PXL_20231031_135129340.jpg PXL_20231031_135438089.jpg PXL_20231031_150625427.jpg PXL_20231031_150636836.jpg
It's quiet and blowing a steady stream of cool air from outside the case directly at both the PPC and 486 heatsinks.
Reactions: wottle
620
View attachment 13954 View attachment 13955 View attachment 13956 View attachment 13957 View attachment 13958
Might have to pick up this type of cooler for mine. The heat was pretty crazy when I ran mine briefly to set up Windows on it. Thanks for the inspiration!
AlpineRaven
31
10
I checked, and it turns out that those can take the Apple DOS Compatibility card (adjusted to modern grammar):
These cards will work in any machine with a (1) '040 PDS and (2) Enough room to fit the card.
This boils down to the following machines:
  • Centris 650
  • Quadra 650
  • Quadra 700
  • Quadra 900/950
  • Quadra 800
  • Powermac 6100/66
yes and Quadra 700 you will need to modify the case lid & it will need an adapter to reach the I/O ports (its about 3.5" too short) to be able to use that card which I have here.
Also; I think Quadra 605 can have that card too (I can't remember 100%.)
Cheers
AP
620
Cheers
AP
It doesn't appear a 605 would support the card. At the very least, the opening for a network card isn't large enough for the card connectors, so the back plate would need to be cut out.
AlpineRaven
31
10
I meant Quadra 660av - not 605 - my fault as I wasn't thinking straight
Cheers
AP
Reactions: wottle
