@KennyPowers How are you getting on with the restoration?
Quite well. I got the pads all cleaned up, verified continuity on just about everything in the capacitor goo area, repaired two broken traces (my first time doing that), and replaced the caps and the 4 previously-mentioned ICs:
At first it didn't chime or '?'. After some discussion on Discord, I finally just went even more nuts with the IPA and it started chiming and booting right up. Must have still been some flux residue in exactly the wrong place.
Two of the 3 hard drives that were installed in this thing appear to be dead, including the original 80MB Quantum. The other two drives are beefy Seagate ST11200N 1GB drives. One of those appears to be dead, and the other one was empty when I got it to mount. I'm booting the machine off of an internal BlueSCSI right now, and I'll probably permanently install that instead of any spinning drives. That freed up the external 5.25" bay for a spare AppleCD 600i I had laying around. I don't have anything cool to put in the external 3.5" bay unfortunately.
The unmarked mystery accelerator appears to work without installing any software/extensions/control-panels/etc. When I remove it, the system is noticeably slower, diagnostic programs don't see an FPU, and only the onboard RAM is detected. When I stick it in, the system boots up much faster, the FPU is seen, and the 16MB of RAM installed on the accelerator is detected. Since it looks kind of similar to a MicroMac ThunderCachePro, I downloaded and installed the tcpv1.0 extension from
here. Adding that extension didn't appear to do anything other than make the machine beep twice at the boot screen before showing the desktop (I'm using System 7.1). I'm not sure what the two beeps mean. Installing the thunderv1.2.3 control panel (for the Thunder & ThunderCache accelerators) from that same link just makes the system hang before getting to the desktop. But, like I said, the mystery accelerator appears to work fine without any software ¯\_(ツ)_/¯
The actual Power Workstation chassis is pretty much pristine, so not really any restoration needed there. I think all that's left to be done at this point is to retrobrite the yellowed Performa case parts so they match the painted metal Power Workstation in the middle. I'm in Pittsburgh, so I might have to wait awhile for a sunny day
