4.5V Battery Replacement for Early Compact Macs?
68kPlus
31
6
Hi everyone,
Looking to find a way to replace the expensive, hard to find 4.5v battery for the Macintosh Plus in particular. The closest replacement is the Exell PX21, which costs around $50 AUD here in Australia, and the cheapest is the Unicell A133 4.5V which is $45.
There are some German adapters that are also expensive that convert 3x LR44 to the PX21, but I can't seem to find them cheap.
Any ideas?
YMK
451
365
If it will tolerate 4.8V, I'd use a quad AAA holder and stuff it with Eneloops.
They're rechargeable, won't leak or explode and have a low self discharge rate.
There's also the 6V 476A, which is cheap and can be dropped to 4.5V with diodes if needed.
VicNor
Sweden
A buddy of mine has 3D-printed a holder for three LR44 coin cells. He uses a metal strip to connect the bottom battery to the connector in the computer. Good enough, I guess? It's not like keeping the time (over time) is super important on a Plus anyway. I'll imagine that one would need to replace the LR44/SR44 at least once a year
Reactions: Jockelill
rikerjoe
256
I went with the triple LR44 route for my Mystic Color Classic. I found a battery holder here.
MacOfAllTrades
257
261
I used a cr2032 cell at 3.5V in my se. I understand the old macs tolerate a wide range of voltages for this purpose and many use 2032.
I got this one
But many exist. Some with wire leads built in (which I think makes more sense for your PLUS).
these cells don’t blow up like the originals and they still last a long time. Any leakage they have in odd occasions is much less as they simply don’t have much
Reactions: indigo_k
misterg33
69
I've used AAAs in stuff like this:
If you have one of the old dead batteries, you can snip the connector end off of it and use some heatshrink to connect it. You don't have to order from Amazon either. Stuff like this is available on most electronic and hobby sites. And I think there are some pre-made ones on ebay.
vtgearhead
101
42
Burlington, VT USA
Another possibility, which I used in my Plus, is to use three LR50, which just make the size of the 4.5V battery.
The (expensive) Excell replacement batteries are actually (3) LR50 cells spot-welded in series. I haven't tried it yet, but I bet three individual LR50s with heat shrink around them will work just as well. The combination is a wee bit longer than the OEM battery so tension should hold everything in contact.
rikerjoe
256
Update. The triple LR44 setup didn’t last very long for me, with one of the cells going flat in less than a year and thus not retaining enough voltage to preserve the settings. A little over a year ago I opted to try a 3.6-V AA-sized ER14505 I purchased from Mouser for a little over $8 - I know, a bit pricy for a battery. I opened my Color Classic Mystic this morning and measured the battery voltage, and it’s doing fine, measuring 3.66 V after a year.
Reactions: YMK and JDW
vtgearhead
101
42
Burlington, VT USA
That makes great sense for almost everything. But, the Mac 128, 512ke and Plus have a battery compartment on the back intended for a 4.5V battery that's long unobtanium. Stacking 3 LR50 cells gives you the right voltage and fits perfectly in the existing holder. But for anything with an internal battery I'll go with the AA sized 3.6V cells. Some systems (Amiga) expect a rechargeable battery. In that case I use a schottky diode to prevent reverse current flow. Most have a forward voltage drop around 0.2V.
Reactions: Nycturne
Elemenoh
460
449
Bay Area
I went the AAA holder route for mine. I popped off the top bit to get it to fit. A little snug but it works.
Reactions: YMK
2,224
After reading your post, I searched Amazon Japan for one of those ER14505 batteries and found a cheaper price than you paid:
I see those are NOT rechargeable, making the cost of replacement something to ponder. I therefore look forward to hearing updates from you about when it dies. If it lasts two years, it's probably worth the price.
Not sure of the stock CC motherboard draws the same amount of current as the LC575, but I measured the current draw from my board (from the PRAM battery):
LC575 Current Consumption: 63µA @4.5V
With a triple LR44 kit attached, that often gives me about 70 days of use. Pretty pathetic. LR44's are roughly 115mAh rated batteries.
But your battery seems to be 2600mAh rated, albeit with a fairly large drop from the nominal 4.5v. Even so, you said your 3.6v-rated ER14505 measured 3.66v after 1 year, which suggests it is higher than 3.66v when fresh. 3.8v? Because that is unknown, let's assume 3.7v for now. Using a battery life calculator ("Disarchge Safety" set to 6%), we have this:
4.4 years
Now if that is true... Wow! That would definitely be the way to go for the stock CC motherboard and LC575 too.
Reactions: rikerjoe and YMK
YMK
451
365
Self-discharge rates should be considered for these very low drain applications.
CR123A batteries are another option. They're larger than the stock lithium batteries, but around half the size of a AA.
They're available in:
  • Non-rechargeable lithium
  • Rechargeable lithium
  • 3-cell rechargeable NiMH
The NiMH option is a more compact alternative to the triple Eneloop setup and should be the lowest explosion/rupture risk.
Reactions: rikerjoe and JDW
vtgearhead
101
42
Burlington, VT USA
I had originally planned to put heatshrink tubing around three LR50 cells, but simply stacking them in the Mac / MacPlus battery compartment works fine. The contact pressure holds everything together.
2,224
That link is now dead. And while I did another search for them there, shipping is rather pricey, and they come in oddball numbers like 5pcs. Since you would need 6pcs for two Macs, 5pcs isn't really that great a deal. I see the same here on Amazon USA:
So 5pcs for $11.49, which means you have two wasted. Or you can just buy the Excell battery for $12.95 and nothing is wasted:
Here in Japan, Amazon shows that 5-pack for a crazy $60 equivalent. Only AliExpress makes sense. But again, the quantity is oddball. If they had a 3pc or 6pc or 9pc set, that would be best.
What I've done in the past is have a family member ship me a couple of the Excell batteries whenever they had something else they wanted to ship to me. Because they are alkaline, there were no shipping issues. And they last a very long time in my Mac 512K machines, usually a couple years if the machine is unplugged all that time. No leaking issues with them either.
