Interware VDR-2A - SE/30
Drake
Emeritus Board Member
795
On my quest to build another money pit that looks ridiculously good I happened across a rare bird for the SE/30...
The Interware VDR-2A *drum roll*
The card itself enables a secondary output over DB15 at a resolution of 640x480 with "Millions of colors" (I stop counting colors if they aren't in a box of crayons).
Using a DB15-HD15(VGA) adapter the SE/30 suddenly becomes a 27" behemoth.
*pictured here: The Maceffects SE/30 running System 7.5.5, 64mb RAM, BMOW Rominator and BLUESCSI*
Oooh Interware Fwiend! :D
I have one of these too, in an SE/30 purchase from Buyee - the DIN connector has a few bent pins, but will try giving mine a good go. Did you need any special drivers/extensions to make it work?
Drake
795
Works without drivers, I did chase down an interware suite but it can't detect anything in the slot. (Not that I'd expect much tweaking outside the OS adjustments).
DeChief
22
39
Nice! I've got the VDR-1A version of this card, do you know if there's a way to get it to output 640*480 at 31KHz? Mine refuses to do anything but 35KHz unless I bump up the resolution, it turns out the original Mac monitors can sync to that horizontal frequency which I was previously unaware of.
Reactions: nottomhanks
Drake
795
I am unaware of any way to change the refresh rates unfortunately :(
  • Sad
Reactions: DeChief
AndyDiags
95
168
@Drake
What kind of DB15-HD15 adapter did you use to get this connected to a VGA input? Is it one of the ones with jumpers, if so did the jumper configuration modify the resolution output?
I have the same Interware VDR-2A card and want to connect it to my OSSC.
Interestingly, my comes with a rom Ver1.03-1 where as yours in Ver1.04.
Drake
795
@Drake
I'm just using the standard Amazon converter without jumpers which auto configures to 640 or (I believe 1024) depending on machine. I don't know if the interware is capable of more 640.
If/when I get a programmer I'm happy to dump the ROM for posterity.
Reactions: AndyDiags
nottomhanks
102
Hey! Just resurrecting this thread, I have the VDR-1a with rom version 1.01.
Could one of you make a copy of the newest rom and send it to me? I’ll pay for it.
also, does anyone know how the dip switches work on this thing?
craig
