MicroMac Carrera040 Accelerator — Audio Fix for SE/30
2,150
I'm pleased to report there is now a fix for audio glitching when using a Carrera040 accelerator card (original or clone) in an SE/30, thanks to a revised Control Panel from @Bolle and GeekDot. I have uploaded it to the Macintosh Garden here...
I personally do not own that card, but I do hope this helps those of you who do.
nekogahora280
46
I'm currently planning to post Micromac's Carrera 040 on my SE/30. i Even if you change your ID with "I Wish" and start it freezes. It seems that you will probably need a dedicated SE/30 control panel document. However, Macintosh Garden has disappeared. I was able to download it from another site, but this time I'm having trouble unzipping it. Is there a site where I can download and use it?
2,150
I checked Macintosh Garden just now. It's working. I searched for WISH I WERE, and the page appears just fine here:
The Control Panel from Bolle is found on the Garden here, and I confirmed just now that the page displays just fine:
I do not own a Carrera040 and therefore cannot confirm anything about it. My post back in 2023 was simply made because my friend Kay Koba told me about the audio glitching and I was pleased to later learn it was resolved, and I wanted to share that info.
You have two choices to UNSTUFF SIT files:
1. https://theunarchiver.com
2. https://macintoshgarden.org/apps/stuffit-deluxe-1605-final-version
I personally use #2 above. In fact, I am the one who uploaded that to the Garden. Works well even on macOS Sequoia on Apple Silicon.
Reactions: nekogahora280
nekogahora280
46
downloaded CarreraSE30.dsk,
which I think is CDEV, but I don't know what to do with it.
Do you know how to convert it into a file that can be read by the SE30?
2,150
On Macintosh Garden, DL#1 is this...
I downloaded that, and it looks like this...
Previewing the contents looks like this...
When I bring that file into Basilisk II, it looks like this...
When I unstuffy the file within Basilisk II, the result looks like this...
When you put it inside your CONTROL PANELS folder and then open it, it looks like this...
I cannot provide more info than that because I don't have the Carrera040 card to test.
nekogahora280
46
"I asked for help on Twitter (X), and it was arranged for the files to be saved onto a floppy disk and sent to me by mail. My lack of knowledge about file formats, compression, and decompression back then is affecting me now. The files will arrive in a few days. Currently, the images have a grid overlay."
Bolle
99
I can see a Daystar adapter peeking out below your Carrera040 there. Interesting to see it's running at all. The jailbar view is as far as you'll get. The patches SE/30 control panel is not going to do anything different as the bars you're seeing are caused by a hardware issue of the Carrera itself.
The only way to run the Carrera040 in an SE/30 is by using one of my ethernet/adapter combo cards.
No other adapter properly supports the Carrera040.
nekogahora280
46
Wow, that's great to hear from you!
I'm new here so please forgive me for not knowing much.
Where can I get the adapter board you mentioned?
I live in Japan, is it possible to get one?
2,150
I am embarrassed to say it, but because I never owned the Carrera040 card, I never read all the details. I learned something new today.
@nekogahora280 大変申し訳ございません!🙇‍♂️
Sure enough, the Carrera040 discussion below says it requires Bolle's adapter (not the ARTMIX Japan TS Adapter):
That's very important info! Especially for folks like me who have the ARTMIX TS Adapter (and a Turbo040). I never bought Bolle's adapter because I have the TS Adapter and it works with my T040. But it is now 100% clear that you MUST buy Bolle's Adapter if you want to use the Carrera040. But when you buy Bolle's Adapter, you get Ethernet too, as a bonus! Have a look...
@Bolle has no online web store. You need to send him a PM to arrange a purchase, either a PM here on TinkerDifferent or on the 68kMLA forum.
nekogahora280
46
「Your account is currently awaiting approval by an administrator. You will receive an email when a decision has been taken.
It was displayed. 」
I registered yesterday so it will take a few days.
We also discovered that there is no online shop.
You should be able to find it even if you search the web.
I'll have to get Boll's adapter to avoid wasting my Carrera040 investment. It's a shame that the ArtMiX adapters available in Japan are not compatible.
Thanks.(^^)
2,150
@nekogahora280
You are saying you registered at the 68kMLA forum, and that is fine. But you don't need to wait a few days. You can send Bolle a PM here on TinkerDifferent. Simply hover over his "Bolle" name in this thread and then click "Start conversation" as shown below.
nekogahora280
46
@nekogahora280
Dear Bolle,Greetings. I am contacting you upon the recommendation regarding the adapter for using the Carrera040 with an SE/30. I reside in Japan and would like to inquire whether it is possible to proceed with a transaction. I look forward to your kind response.Sincerely,
@nekogahora280
I just sent a message.
Thank you for letting us know.
It would be good if it was resolved.
nekogahora280
nekogahora280
46
I installed CDEV for SE30.
The thick lattice remains as expected, but the file works and is 040Fast
It seems to be working. Before, when I ran the bench software, I freezed.
I had it but now it's finished without error until the test is over.
You will be waiting to get the corresponding adapter.
nekogahora280
46
Can confirm, I am running the Carrera 040 with Bolle riser card in an SE/30.
Thanks to you, I was contacted last night
We are currently taking measures.
The original DayStar adapter works, but the screen display does not work properly.
nekogahora280
46
@nekogahora280
Thanks to you, I was able to contact Mr,Bolle.
thank you. All that's left is expected to arrive and work properly.
