Making a DB19 from a DB25
2,300
Since DB19 are difficult and expensive to come by these days I waned to see if I could make one out of a DB25 I had laying around.
Step 1: Cut off 6 pins to make it a 19
Step 2: Cut the shroud and top pins off
Step 3: May as well match the hole up even if we won't be using it.
Step 4 check fit... Too wide. We'll have to chop off some of the back shroud too. This affects the strength of the shroud so I added some solder to help hold it together. I'll also add some super glue to hold the plastic and shroud together.
Step 6 final fit test.
This is a good enough solution for your own personal use but quite a hack job indeed.
You can buy DB19 on eBay or a A2Heaven has a PCB that mimics the pin out. But the DIYer in you may want to try this if you have a few spare connectors laying around.
I'll be using this to connect a SmartPortSD.
Reactions: Daniel Hansen
Drake
Emeritus Board Member
795
This reminded me of something I had tucked away. Was attached to a IIc I bought years ago.
Reactions: eric
