Compact Mac Caps List
Logic Boards:
Cap Values ->1µf - 50V SMD10µf - 16V SMD47µf - 16V SMD100µf - 6.3V SMD220µf - 16V - Axial470µf - 16V - AxialGuides
Mouser ->
Digikey ->??????
SE/3011011RecapAMacMacCapsConsole5
Classic17RecapAMacMacCapsConsole5
Classic II (RevA)183RecapAMacMacCapsConsole5
Classic II (RevB)2123RecapAMacMacCapsConsole5
Color Classic162RecapAMacMacCapsConsole5
Analog Boards:
Mouser1000µf 10v1000µf 16v1000µf 35v2200µf 10v2200µf 35v470µf 25v100µf 25v - radials22µf 50v4700uf 25v220uf 16v10uF 160v33uF 40v3.9uF 450VDC (film)Guides
Digikey
SE & SE/3014112111JDWMouser Cart (JDW)
Classic 1 (A)Determine Rev A or B (F.2-6 Power/Sweep)
Classic 1 (B) & 2 (B)111212MacCaps
Classic 1 & 2 (int)RecapAMac
Color Classic1212RecapAMacMacCaps
Stephen
BetterBit
215
265
San Francisco
Logic Boards:
Cap Values ->1µf - 16V SMD1µf - 50V SMD10µf - 16V SMD47µf - 16V SMD100µf - 6.3V SMD220µf - 16V - Axial470µf - 16V - AxialGuides
Mouser ->
Digikey ->???????
Analog Boards:
Digikey
Excellent use of this format, Eric. Very nice!
fehervaria
171
North Germany
Should we extend this with the Analog and Logic Boards caps for the 128K, 512K and Plus?
Same with the different floppy drives. I think @JDW has cap list for the floppy drives and PSU caps for the SE&SE/30s.
Reactions: wottle and JDW
Elemenoh
428
415
Bay Area
Nice work! It'd be nice to note the sizes for each cap, especially for analog boards. SMD size codes can be confusing to newcomers and some analog boards have some caps in odd sizes to provide enough clearance. For example IIRC there are a couple 330uF caps on the Color Classic AB and one of them is short and fat where the other is taller and skinnier.
Mu0n
649
606
Quebec
I assume these are all for North American values? I remember that I had to watch myself when searching for component lists back in 2019, I often stumbled upon the values needed for European/International analog boards, which sport different caps.
jamiros
Hello! I just got a Macintosh SE, and I want to recap. I do have the list for it from RecapAMac. 1µf - 50V x 1 and 10µf - 16V x 10.
I'm new to electronics; I've only soldered some mods to consoles and used breadboards. I don't know what I should look for. Can we add it to the list?
Or can someone help me with some direction on which axial capacitors to buy? I would greatly appreciate it.
ScutBoy
343
Northfield, MN USA
You can use the Console5 link above to order the kit that has the correct caps that you need. Make sure it's the one with tantalum caps.
Reactions: RetroViator
caver01
144
there is a mistake in the logic board table for the Classic. The 1uf should be a 50v. fix that and you can delete the first column.
1,968
Hmm, maccaps shows it being 1uf 16v - but others show it being 1uf 50v. (of course you can replace it with 1uf 50v fine) - I'll update just to remove the column and confusion.
Also maccaps seems to be dead - though pages are still on archive.org.
  • Sad
Reactions: Elemenoh
caver01
144
I am looking at mine and it’s a 50v.
Reactions: eric
