Macintosh SE or SE/30 Fan Bracket
reallyrandy
81
New Jersey
I know this is an old thread but for those of you who are sans 3D printer, where do you get your 3D prints made? I tried PCBway for the fan bracket on Post#1 of this thread but the shipping is stupid expensive for an $8 part to New Jersey. there's no chance I'm clicking the "Place Order" button on that!
alxlab
322
www.alxlab.com
You could try JLCPCB and see what they're charging.
Alternatively I could make one for you out of black PETG for $8 USD. I'd have to calculate the shipping though from Montreal to your address. PM me if your interested.
This Does Not Compute
339
486
Check with your local library, a lot of them have 3D printers now and the librarians can help you use it!
339
486
I keep seeing this on the Internet, which magical places have 3D printers in their libraries?
One of the major county library systems in the Twin Cities (Minneapolis-St. Paul) offers it: https://www.rclreads.org/3d-printing
As does the St. Paul Public Library system: https://sppl.org/innovation-lab-equipment
Along with another Twin Cities county library system: https://www.co.dakota.mn.us/libraries/Using/iLab
That's just near me.
Chicago: https://www.chipublib.org/maker-lab
Los Angeles: https://www.lapl.org/labs/octavia-lab/3d-printing
Denver: https://www.denverlibrary.org/idealab3D
Washington, D.C.: https://www.dclibrary.org/using-the-library/maker-space-and-machinery-fabrication-lab
Boston: https://guides.bpl.org/c.php?g=1308326&p=9632039
Atlanta: https://www.cobbcounty.org/library/services/3d-printing
The list goes on.
davewongillies
45
50
CA, USA
The list goes on.
I'm in SF and SFPL only offers 3D printing to youth aged 12 through 18: https://themixatsfpl.org/made-at-the-mix
nickpunt
I'm in the process of finalising a production PCB design and designing a 3D fan housing model (similar to the one in this post) which would be able to hold the circuit board securely, I think the best place to locate the board (and therefore sensor) would be horizontally just above the fan, near the flyback cage, and in the 'dead' air space just below the top of the case, where the internal temps are likely to be highest.
I've also designed a test circuit and written a separate program for testing, which I'm in the process of wiring up to the Mac's serial port, so I can gather and save data to plot internal temp / fan PWM / fan RPM over time, which may be interesting for the community. Just need to wire it all up and spend some time capturing and plotting the data... I also plan to make some recordings, to compare the sound levels from stock fan / Noctua at full speed, and what the fan sounds like at different temperatures.
I'm thinking of making a small run of these boards and could make them available for a reasonable cost (£15 or less, depending on number).
Do message me if you're interested so I can gauge whether to order some parts for more than just me! Be aware though that this design requires a 4-pin PWM fan rather than the 3-pin style (which will always run at full speed if connected to the Mac's 12V supply).
Hey Ross, this looks like a fantastic solution to compact Mac heat issues. Do you have any updates on this? I imagine many people would be interested in what you've built as you've put in a lot of effort to solve this. Thanks!
1,742
Here's a fan bracket I made for the Macintosh SE or SE/30...
I added your fan bracket to my JLC3DP price quote today, hoping to have in printed in PA12-CF (Carbon Fiber reinforced Nylon), but JLC says some portions of the bracket (as shown in red below) are 0.5mm or less. Do you think that is a non-issue and I can safely just tell them to print it anyway? (It is interesting that only one side is showing red and not the other. Imperfect symmetry?)
alxlab
322
www.alxlab.com
Yeah I wouldn't worry about it. It should come out fine. If it doesn't I'll pay for the print.
Personally if I was ordering from JLC3DP I'd try out out the SLS(Nylon). It would end up stronger than FDM PA12-CF but more flexible. Flexibility shouldn't be an issue in this application. It's also cheaper.
1,742
Thank you for sharing your thoughts.
I actually often buy JLC3DP prints in SLS Nylon because of the lower price. But it can be almost too flexible at times. For example, I had a 040 heatsink clip, created by @jmacz , printed in SLS Nylon but the protruding arms ended up not being straight enough due to the flexibility of nylon. He kindly printed one in reinforced carbon fiber and shipped it to my parents address in CA when I had my recent CA trip, and when I later tested that version, the increased rigidity make it clip onto the CPU perfectly.
I also printed a case created by @Javmast3r for the SPIISDv2 by @Kay K.M.Mods in Nylon, but Nylon ended up not being as good as JLC Black Resin, even though resin is comparatively more brittle. So I was glad I had the case printed in multiple different materials at JLC so I could compare, but I will admit that it did cost me more money to do that.
I suppose it could be argued that having a more flexible material for the SE fan mount could increase vibration dumping, but TPU would offer more damping than Nylon, at the expensive of even less rigidity.
Have you tried printing in different materials to see the difference, and determine how much rigidity is actually needed?
jmacz
46
37
If it’s just the bracket for the fan, wouldn’t PLA work? The temps on the bracket would be minimal and PLA would be strong enough for that application and cheaper. I have drive cases printed out of PLA which do just fine, and they get banged around more than that fan bracket will.
Made a fan bracket for my Rocket (long story) out of PLA and it’s doing fine. The one I made for @JDW (and also myself for a different project) had the clips on the CPU hence went for a CF added filament, but this Rocket application has the clips on PCB so no need. Likewise I would think PLA should do fine for this fan bracket in this thread.
Reactions: bakkus and JDW
alxlab
322
www.alxlab.com
No problem. Yeah your absolutely right that the SLS Nylon can be too flexible.
I haven't tried it for the SE/SE 30 fan bracket so it's just an educated guess that it would be no problem for this particular application. I guess it could be made with TPU but maybe that would be too flexible? It would definitely be much hard to print.
The only materials I tried printing the bracket in are PLA and PETG. I used the PLA for prototyping and then used the more durable PETG for use in my Macs. ASA/ABS, nylon and PC should all work also but are more difficult to print with due to it's tendency to warp. If you printed with JLC3DP I would expect them to be able to print with those materials no problem though.
