New Toy: Dell Latitude D630 (Windows 7 Pro)
Volvo242GT
400
235
Currently Duvall, WA
One thing that might be worth doing, is to upgrade to a Penryn die Core 2 Duo chip. I had a D830 about 10 years ago. Ran Win 7 Ultimate on it. Was a decent machine, but the fan would go bonkers while either watching YT videos or using Google Maps. Had the 2.2 GHz T7500 processor installed. I upgraded it to a T9500 (the 2.6 GHz Penryn die chip). Fan rarely revved up at all after the swap. After seeing the improvements with it, I upgraded both of my parents' machines from the T7500 and T7700 to a couple T9300 chips (the 2.5 Ghz version). Both of their machines ran much cooler.
2112st
302
117
Northeastern New Jersey, USA
Thanks for the suggestion! However, 1) I don’t have the technical knowledge to do that (I’m just a writer/illustrator) and 2) this Dell laptop will be primarily used for writing: fiction, essays and poetry. So usage will be very light on this machine.😎
Volvo242GT
400
235
Sure, not a problem. It's not much more involved than doing the keyboard swap, and, if your machine has the nVidia Quadro GPU installed, it might be worth at least going in there and replacing the old thermal paste with some fresh paste to keep the chip from suiciding itself.
Reactions: 2112st
404
193
We're the CPUs socketed on those laptops?
404
193
Jeff,
Yep. They were. Unlike Apple's soldered chips on the same era MacBook/MacBook Pro machines.
Thank you. Yes, on my E6410 they were also socketed. But on the D430 which is a family relation to the D630, the CPU is soldered. Probably because the D430 was very compact for its day.
I feel like the D series was a high point for the Latitudes. Not the pinnacle, because Latitude has been around so long, it's had many highs and lows. But for the time, the technology, and for all time, the feel and styling of the D series was fantastic, IMO.
Volvo242GT
400
235
Agreed on the D series high point. Those, and the Inspiron 8500/8600/9100 machines were pretty good. My sister and I had an 8500 and an 8600, respectively. Hers was bought new in 2003. Mine, found it in 2010 at RE-PC in Seattle with a broken display and a bad video card. Replaced the nVidia card with a Radeon 9600, then swapped the broken WXGA display panel for a WUXGA version. Used it as my daily until I got my D830 in early 2013.
Reactions: trag
404
193
At least, I might add an additional 2 gigs of RAM, because I might install an older version of Photoshop on here. But this machine will remain a home unit, and be primarily used for writing. Though...watching this video, I wonder if an SSD replacement is possible for this machine and what the maximum size might be? 🤔
I don't remember what the machine uses and am too lazy to look it up, but...
If it uses a 2.5" SATA drive you should certainly be able to replace it with a SATA SSD.
If it uses a PATA drive, you can get a PATA => MSATA adapter for about $15 and install a somewhat more expensive MSATA SSD. NewEgg had the Kingspec 1 TB MSATA for ~$45 a few months ago, but now it is closer to $60 again.
The D430 used a 1.8" ZIF PATA and those 1.8" PATA drives were slowwwww and the vast majority were under 100GB in capacity, although Toshiba did make a spinny 1.8" PATA at 240GB. A 1.8" ZIF to MSATA adapter was a huge improvement.
Sintech makes a large selection of Mumble to MSATA adapters.
Reactions: phunguss and 2112st
2112st
302
117
A question for you folks-what's a good piece of software to measure the temperature of the CPU? Redoing the thermal paste on this machine is a bit more involved than just removing the keyboard, as it involves the removal of the display and a fair amount of disassembly.
starlite
685
350
the United States
www.macdat.net
If it gets above 80-90C under full load, that would be a bit on the hot side. Hard to say what's normal for a D630 since every laptop is different, but between 40-60C at idle is fairly normal I think?
