SuperDrive (floppy) maintenance
2,151
There is yet another case that I posted on FaceBook yesterday, and have been speaking to @fehervaria and others about. My case pertains to bad 1.44MB SuperDrive heads. That problem has nothing to do with Zero Track or Motor misalignment. In my case, I know that to be true because I removed the "bad" head unit and also removed the "good" head unit from a different 1.44MB, installing the "bad" into the "good drive." That resulted in that previously good drive becoming bad — putting in known good disks caused the head to move slightly but then the Mac quickly ask me to Initialize the disk. Putting the "good" head unit into my "bad" drive made it into a good drive. That test provided 100% proof that my problem is not Zero Track or Motor misalignment.
I should add that the previous owner of my bad 1.44MB SuperDrive apparently had moved the upper head up too high, which is a big no-no. There were two pieces of evidence which proved that happened in the past:
  1. The ribbon cable which connects to the main board in the back and which fits into the black, back-side groove inside the head unit, was complete pulled outside its groove and sitting right next to the other ribbon cable. To pull that ribbon cable out of its groove requires moving the upper head very high.
  2. Using a magnifying glass, the place on the metal piece at the back of the head unit which bends when you lift the head was very slightly bent upward even when the head was down. Checking all my other 1.44MB Superdrive show that place on the metal piece to be perfectly flat. I was able to press down hard on the very back of the head unit to make the bent metal piece go flat, but sadly, that didn't resolve the "bad" head unit's read/write problems.
I've cleaned all my drives and the heads using 100% IPA and fully lubed them properly too. In fact, I cleaned the "bad" head unit many times with IPA and a swab, taking great care not to damage the heads in the process. Nor did I pull the upper head too high. I did multiple cleanings because in the past I had one drive that refused to work until I had cleaned the heads 5 times with a swab and IPA. Yes, that other drive had THAT much gunk caked onto it! Very hard to see too unless you use a magnifying lens.
So because I have a confirmed bad head unit, I am seeking a replacement. No, not an entire drive replacement because that is wasteful. Only the heads are bad. And no, the ribbon cables don't appear to be broken either, although I didn't fully disassemble my "bad" head unit.
All said, some floppy drive problems don't necessarily pertain to the lack of cleaning or a Zero Track Alignment problem or a Motor Alignment problem. There is a category I label: "MYSTERY"
What all this shows is that you really do need more than one floppy drive of the same type which is cleaned, lubed and working good. Then when you have issues with another drive after giving it a full clean and lube, and after examining the heads to find they look OK, you should then carefully swap heads with your good drive before you resort to Zero Track Alignment. That's because Zero Track Alignment is troublesome to do. If your head unit is bad like mine, but you don't know that and just forge ahead with a Zero Track Alignment, you will end up with a bad head unit AND a problematic drive body too.
Reactions: astron
astron
Thanks for this post! I just opened up cleaned, and lubed my LC II's drive with @JDW 's video. I thought maybe something was dirty or gummed up but it asks to initialize every disk still. Heads were fine but I swabbed them anyhow. I have a Sony drive with a non-Omron ejection motor (the gear looked fine and there was plenty of clean grease so I'm not worried). What's even weirder is the system hangs when trying to initialize any disk in the drive, and I have to cut the power and manually eject the drive.
I don't have another 1.44 drive on hand to swap heads with...so what replacement 1.44 meg drives are compatible with the LC II?
2,151
I am the furthest thing from an expert regarding the LC one, two, or three series because I’ve never owned one. But based upon what I’ve seen, some of those machines used manual inject floppy drives while others were auto inject. Those two drive types are quite different.
astron
It's probably auto inject, because it's model number MP-F75W and it's from before Apple added the little notch beneath the disk slot in the plastic.
2,151
....what replacement 1.44 meg drives are compatible with the LC II?
For the LC models that use the auto-inject drives (with the skinny disk insertion slot in the plastics which looks like an SE or SE/30, not like a PM6100), most any of the F75W series should work, including MFD-75W-01G and MFD-75W-02G.
Reactions: astron
Mk.558
112
45
Hey @JDW, as our resident Japanese expert (
), does this page offer anything interesting to us today?
I'm trying to hunt down any Engineering Reference Specification documents for the MP-75W 1.44 drive. We have the 800K one on bitsavers, but I"m not seeing anything else...perhaps there might be someone in your quarter that might be able to help us out?
2,151
I’m traveling internationally at the moment and cannot provide you the perfect answer at this time. I can only say that Japanese web page does not include any engineering reference specification and instead covers disassembly, cleaning, lubrication, head related topics, and testing, with various photos.
Quick tip. Google Translate has gotten much better over the years but ChatGPT is excellent because you can give it context when asking for a translation, which helps improve the translation overall. Not only can you get a translation but you can ask it to give you a condensed summary too. (My above summary is even better, but AI will get better over time.)
Mk.558
112
45
yeah I remember when google translate was ... it helped, and it was better than nothing, but only just. I did look at some of the other pages with some translation and it made enough sense.
His networking and AFP pages are kind of a mess... :)
I've asked on VCF, we'll see what happens. I don't think head specifications would even been the ERS...that's more like internal document stuff...Maybe we'll never know.
2,151
I'm back from my trip. After searching far and wide, I simply could not find any schematics or technical whitepapers on the topic of these 1.44MB SuperDrives. That's not to say such information doesn't exist. It's only to say that I myself could not find it. Hopefully, someone better adept than me can come along with a PDF that gives us the info we seek.
For now, the only thing I did find was the following page on LEM about "Interchangeability and Compatibility of Apple 1.44 MB Floppy SuperDrives":
Reactions: S. Pupp
fthain
Regarding the manual-inject FDD (Mitsubishi MF355F 592MA), here is a link to a recent video from @techknight in which he discusses disassembly, recapping, track zero alignment and so on.
The MF355F 592MA that I've been working on recently had at least six screws fixed in place with green Locktite: two for the stepper motor (see photo), two for the heads and two for the PCB. Thanks to the video from @techknight it's clear now why all of those components have to be kept in alignment. So next time I recap one of these drives, I will mark the PCB and frame prior to disassembly so everything goes back together in exactly the right position.
This drive is different than the auto-inject drive described in Paolo's PDF in that this stepper motor has an 18 degree step angle (so says the sticker in the photo). If I understand correctly, that means that there's no point in rotating the stepper motor stator beyond +/- 9 degrees when aligning the heads with track zero. (That works out to about +/- 1.57 mm or 0.062" at the circumference given the motor's 20 mm diameter.) [Edit: that's assuming the motor is moved by one increment at a time when it seeks to track zero. However, it could be moved two at a time. In that case, I'd need to search over a 36 degree range to find the correct alignment, like the drive in the PDF...]
It's probably best to align the heads with the centre of track zero. One way to do that would be to follow the usual trial-and-error procedure but instead of stopping when MacOS is able to mount the disk, mark that angle and then keep adjusting in the same direction until mounting fails again. Then split the difference. An alternative method would be to attach an oscilloscope to a suitable test point on the PCB and, using a known-good floppy disk, measure the signal from the read head (or its amplifier) to find the stator angle which maximizes the signal.
Either way, I expect the main difficulty will be in making precise angle adjustments. I wonder whether those two holes on the back of the motor were put there to accept a lever -- given a sufficiently long lever, tiny angle adjustments would be easy.
