I spotted a "for repair" CC analog board on Ebay a few weeks ago. Seller said that the board was VGA modded and worked fine for a while. Seller then attempted to undo the VGA mod, but something got messed up in the process, and it stopped working. I got this board thinking I could try to repair it, and if not, I could at least keep it for parts.
It arrived the other day, and after careful inspection, I spotted a problem that I figured was the culprit. The tiny J78 jumper was not re-soldered properly. In any case, I wanted to try a VGA mod on this board, so I did all the steps very carefully and properly (including the removal of J78). Then I tried it - and it worked! I got a nice 640x480 picture, and after some picture adjustments, I got to try a few games, everything ran perfectly. I was very careful not to make any adjustments on the CRT itself - all the picture adjustments were only done on the analog board pots in the back.
But one thing bothered me - even though I turned the green sub-brightness pot all the way down, the green sub brightness was still too high. I could see a green background all the way around visible picture, and there was never a proper black color displayed on the screen, it was always green-tinged and visibly bright. Watching the @JDW 's picture adjustment video and seeing the CC service manual, I saw that part of the adjustment process is to tweak the larger PL2 pot which controls the "VG2", whatever that is. So I turned that pot a bit - and green sub brightness became perfect! I was really happy with the result, turned the computer off and left it for the day. The next day I tried it again, and that's when the problems started: The picture was really flickery and unstable, kind of scarily so, considering that there were buzzing sounds coming from somewhere on the board each time the picture became unstable. I turned the PL2 back up a bit to where it was originally, and the problem seemingly stopped. Then I turned it back down to make the picture look the way I wanted, powered the computer off - and the next time it would not power on. The front LED just blinked quickly. So I turned the PL2 back up - and then computer powered on.
I figured that maybe the PL2 not being turned in decades was a but rusty and losing contact, so I sprayed it with some contact cleaner (while the computer was off). Let it dry and tried it again. It seemed to make things better. I could adjust the PL2 and the picture remained stable. So here I am a day later, and the computer no longer powers on, no matter what
The light on the front just blinks quickly, turns off, and that's it. The high voltage never seems to spool up when I flick the switch on the back. I tried more contact cleaner on the PL2, some more on the AB main connector, turned PL2 back and forth - but no luck.
Did I mess something up by spraying the PL2? Am I just experiencing the same issue that the seller was? I guess I will remove the PL2 and test it somehow first. Maybe transplant the PL2 temporarily from another board to see if that's really where the problem is. I hope someone can help, if you've experienced the same kind of problem.
*edit* I've checked the resistance of PL2 pot while it's still on the board, and it seems to work OK - I measure the range between 0 ohm and 1.1 Mohm while I rotate it (if I measure the other two pins it's the opposite range).
