iMac G4 doesn't chime once I took the HDD out.
neonfire
Cincinnati, OH
I wanted to replace with an ssd adapter, which is now plugged in.
When I turn it on it the fan spins for a moment, and then turns off.
I haven't removed the ssd yet, but wanted to know if there was anything else to look out for while I have it open
Reactions: stompy
neonfire
Cincinnati, OH
I put the original HDD back in and it chimes and the screen comes on, but it doesn't show the happy mac or boot into os9. I kept the CD drive out of it as I don't think it's working. Is the big SIMM in the logic board RAM or ROM? I also notice the smaller SIMM on the outside, which I assume is RAM expansion.
Does anyone have a source for a more modern SSD solution for this Mac?
553
The iMac G4s use a regular Desktop DIMM internal on the logic board, and a SODIMM that is "User Accessible" by removing the bottom base plate cover.
Reactions: neonfire
mac27
145
163
Virginia, USA
www.mac27.net
Depending on which size/model you have here (15", 17", 20"), links to the SSD solutions I have used in my own iMacs are at the bottom of each of those links, respectively.
Note that there are significant differences in terms of jumper configurations between the models.
Reactions: phunguss
