Eric's Apple Network Server 700 tinker log
2,307
Well in a bunch of unrelated issues covering up the real issue which was me being silly I am back up and running, though my install from last year I cant launch any apps at all or smit or anything. I'm just going to start fresh again to refresh myself on the entire process.
One oddity is that the power button wont keep the machine off. It powers down but only for about 5 seconds then powers back up - donno if thats some setting or datacenter thing it's trying to stay on after power loss or shutdown.
359
137
Is there a way to write on multiple line on the lcd screen? control chars/escape/etc dont seem to work passing to `lcdstring`
Does the ANS 700 have the same ROM as an ANS 500?
Here's the version, size, checksum, and md5 of the ANS 500 ROM:
077d.28f2 4096 962f6c13 676809c236138574282fa8416c6c5a6d "./ROM 1.1.22 ANS 500
The ANS 500 ROM has an Open Firmware driver for the LCD which does support some control and escape characters. Open it like this:
unselect-dev
0 value lcd-ih
" lcd" 2dup find-device open-dev dup . dup to lcd-ih to my-self
The number that is output is the instance handle that was opened. It should be non-zero if successful.
my-self may be reset to zero if you type an incorrect command. You can just re-open the device again or do
lcd-ih to my-self
Then you can write to the LCD like this:
" hello" write
Or like this:
" hello" " write" lcd-ih $call-method
The write word for the LCD seems to support the following special characters:
  • 0x08: back space - Left one character and erase it.
  • 0x09: tab - Output lanks to the next multiple of 8 column number.
  • 0x0A: linefeed - Down one line, clear the line, go to column 0.
  • 0x0B: Up one line.
  • 0x0C: lcd-init - Goto line 0 column 0.
  • 0x0D: Ignore.
  • 0x1B: escape - Begins an escape sequence. Only 5B is accepted as the second character. Characters 0 - 9 end the escape sequence (and do nothing). 0x44 (character D does a back space and continues the escape sequence.
Writing beyond the end of a line does a line feed to continue on the next line. I believe there are 20 characters per line.
Characters that change the line number transmit a line number change command (each line uses a different command: 0x80, 0xC0, 0x94, 0xD4). There's other commands (0x01, 0x02, 0x04, 0x06, 0x0f, 0x38). Are the LCD commands documented somewhere?
To use the special characters, put the hex in the string surrounded by "( and ) like this:
" abc"(0A)def"(0B)ghi(080808)jkl" " write" lcd-ih $call-method
Actually, since lcd has a write command, it might be usable as the Open Firmware output device:
" lcd" output
  • lcd.4th.zip
2,307
@joevt oh interesting! I (finally) tried to dump the ROM from my 700 but my collection of cables/adapters/etc must not be correct as I can never get output or input on the OF console. Is there any way to dump this while the machine is running (Is it mapped to a memory location or anything like that?)
I have two options but neither work: USB Type C to RS232 DB9 Serial Port Adapter Cable, FTDI Chipset -> null modem cable -> DB9 to apple serial adapter. I assume it's because it's RS422
And a Keyspan USB->RS422 adapter which is seen in linux as a serial tty, but i get no traffic.
Is there a way I could do this from a vintage mac with a serial port?
How could one call these OF ROM routines from C or while the system is running? I'm not familiar with how all this works.
With the `lcdstring` command this doesn't seem to happen.
2,307
Success! Winning combo was it's the 2nd port on the ANS from the top and just using the kingston adapter to a serial cable:
Reactions: reukiodo
2,307
RAID card installed. Took out the full compute unit as it was easier. the SCSI connectors on the back made it hard to put the card in so i took off one of the stand offs for the external HD connector. Disk drive in the ANS is not working so I pulled out the floppy drive from my childhood 6115/CD and it worked. Booted into the RAID utility with putting the ANS in service mode then `boot fd:dacconf.ns` - Have a BlueSCSI with 3 9GB drives for a RAID 5. Auto configured and now it's initializing the drives.
Reactions: reukiodo
359
137
There's probably a way but I only have apps for Mac OS 9 and OS X - neither of which is usable by the ANS 700?
The ROM is mapped to last 4 megabytes of physical memory. So, one would map it, then copy it.
RS-232 has a single wire for receive and a single wire for transmit.
RS-422 uses differential signalling. You can connect the one wire from RS-232 and ground the other wire for RS-422.
I don't think you can call Open Firmware from most OS's.
If you can't find a driver or reverse engineer a driver from the OS (what does the lcdstring app use?), then you could try reverse engineering the driver from Open Firmware. The Open Firmware driver indicates that the registers for controlling the LCD are 32 bytes at 0x1c000 of macio. This is at 0xf301c000 physical address. command byte is at offset 0x00 and the data byte is at offset 0x10. There's a 1 ms delay used after every write to a register.
Are the ports not marked as modem and printer port? The default port for Open Firmware is modem port.
@joevt Attached is the raw output.
Thanks for the dump. It's identical to the ANS 500.
359
137
Attached all the Open Firmware stuff from the ROM. You can use the tbxi command to dump other parts.
Strange it has the same version as the 8500 v2 / S900 rom.
077d.28f2 "Boot TNT 0.1p..]" 4096 962f6c13          √ 676809c236138574282fa8416c6c5a6d "./ROM PowerPC Mac/ROM 1.1.22 ANS 500 & 700/ROMs/@FFC00000 Entire ROM.rom"
077d.28f2 "Boot TNT 0.1p..]" 4096 9630c68b          √ 2623a0c438045ea04d2cc67310c97743 "./ROM Apple/#1 mac-rom-archive-20110819/9630C68B - Power Mac 7200&7500&8500&9500 v2.ROM"
The ANS 500 & 700 ROM version of Open Firmware (1.1.22) has names for all the words, unlike 1.0.5 so it's easier to read if you don't have 1.0.5 source.
It outputs Open Firmware progress to serial port depending on some external switch that changes the baud-rate (9600 or 38400 or none). I think the switch is a couple bytes in PRAM or NVRAM.
Other info that would be useful is:
dump-device-tree
lspci for Open Firmware (for PCI register dumps)
Non PCI register dumps (but that requires knowing what registers to dump - I would start with everything in GrandCentral (1 MB at 0xf3000000) and 0x800 bytes from Hammerhead.
All the Open Firmware code is in the Part1.txt and Part2.of files.
Open Firmware has a few parts:
  • @startvec at offset 00003C and described by fields >imagesize to >r13-31
  • some assembly stuff at offset 0001BC
  • a list of precompiled words starting at offset 000B74 and described by fields >h.link to >h.name; the last word is pointed to by @startvec.>word-list
  • the main fcode image at offset 007514 pointed to by @startvec.>fcimage
  • a list of other fcode images described by fields >of.next to >of.fcode starting at offset 01C88C; the last image is pointed to by @startvec.>fcfiles
All these parts are in Part1.txt. The fcode is removed from Part1.txt and converted to Forth in Part2.of.
There's 53c94 and mesh built into Grand Central. I don't know if they're connected at all.
/bandit/gc/53c94            scsi
/bandit/gc/mesh             scsi-int
Here is the device aliases for the new PCI SCSI stuff:
/bandit/53c825@11            scsi-int
/bandit/53c825@12            scsi-int2
/bandit/53c825@11/sd@0,0    disk0
/bandit/53c825@11/sd@1,0    disk1
/bandit/53c825@11/sd@2,0    disk2
/bandit/53c825@11/sd@3,0    disk3
/bandit/53c825@12/sd@4,0    disk4
/bandit/53c825@12/sd@5,0    disk5
/bandit/53c825@12/sd@6,0    disk6
There's three choices in chips:
pci1000,f 53c875 NCR,875
pci1000,3 53c825 NCR,825A or NCR,825
But the device aliases are only for the 53c825.
There's an fcode image for the PCI vendor:device 1000:0003 at offset 01D1C4. It determines which chip is being used. probe-device loads the fcode image for PCI device 1000:0003 and 1000:000F.
fcode image 4 at offset 01FE84 is used for the drives connected to the scsi controller. This fcode image is also used by 53c94 and mesh. 53c94 and mesh use fcode image 3 at offset 01F8F4 for tape devices.
  • ROM ANS 500 & 700.zip
Reactions: reukiodo and eric
2,307
I'm running into an issue with installation now that the RAID card is installed. Booting off the CD and that step works great, but after it does the first package install it reboots before doing the second stage (and the notice to move the key to non-maintenance mode) - after the reboot it just drops into a shell that i can login with root and no password. I can start smit and oddly point the package installer to /dev/cd0 (instead of a mount point?) but there I can do a full package install. I never see the Post install guided installer gui. Also after reboot X11 does come up but no login and the cursor is an hour glass and just sits there. Really odd. I did this twice just to confirm I didn't miss something. Any thoughts on what might be going on with the installer and the RAID card?
Correct - just #1/#2
2,307
When I did animations on the LCD panel for a VCF one year, ISTR I just used a lot of spaces.
When I tried spaces to wrap i just get a triple line char at the end and nothing on the 2nd line.
Ok fresh install again. I selected clean install, installp finishes, the next step where ig goes back to "Please wait..." it says 84% and "Creating boot image" then reboots (normally, without the SCSI RAID card it will do one more step here I believe, but dont know offhand).
Next it boots to OF, find the system drive, boots and has a gray screen, gray screen goes away to a text terminal that has this
Here is where I would expect the finalize install GUI to be as it normally is without a RAID card...
Then I can use smit to install all licensed. 271 packages
Reboot and it just sits here:
Also oddly the lcd screen has no info on it. Pretty confused!
359
137
Does lcdstring have a man page?
I would create a new utility that writes directly to the command and data registers like the Open Firmware driver does.
359
137
Is there an Apple document that describes the hardware of the ANS 500/700?
Found this: https://vtda.org/docs/computing/Apple/ANS/HardwareDevNotes.pdf
It doesn't say much about the LCD. It does say writes should have a 1µs delay, (much less time than Open Firmware's 1 ms delay) so you may be able to tweak the command rate.
I think these describe the commands of the LCD controller:
https://forum.microchip.com/s/topic/a5C3l000000BqypEAC/t392075
https://cdn.sparkfun.com/assets/9/5/f/7/b/HD44780.pdf
Notice that line 3 (0x94) is 20 bytes from line 1 (0x80) and line 4 (0xD4) is 20 bytes from line 2 (0xC0).
This is how a 2 line 40 character wide LCD translates to the 4 line 20 character wide LCD of the ANS 500/700.
Does the controller allow addressing individual pixels? Maybe you can program a game on the LCD - e.g. Snake.
572
www.floodgap.com
It's just an HD44780-style controller, no dot-addressable graphics. I'm not sure what's going on there, but it acts like there's something that didn't start in your rc scripts. What do they look like (in /etc)? You may have to boot from the AIX CD, mount the rootvg and pull up a shell to see.
2,307
Can you provide a bit of guidance on how to do this? I'm just not familiar with AIX to know how to get to a shell from the installer or where I should poke around for things like logs/dmsg/etc stuff.
572
www.floodgap.com
Start from the AIX CD. Once you have defined the local console (i.e., the monitor and ADB keyboard), from the Installation and Maintenance menu choose Start maintenance mode for system recovery, Access a Root Volume Group, choose your rootvg (I'm assuming you have only one), choose your file system (probably /), and then Mount File System and Start Shell. You will have a root shell available to enter commands.
Reactions: eric
2,307
Poked around but didnt see any errors in the logs I could find in the recovery mode.
I did another reinstall and was reading the manual and noticed I can run the install assistant anytime - "You can access the Installation Assistant at any time by entering the command install_assist" - so after i got dropped to the root login after stage 1 install i ran it, installed all packages and this time exit to AIX brought me to the CDE login! Unfortunately after login I am just stuck at the blue "Starting the Common Desktop Environment" screen. This is further than I got before but still stuck unable to access CDE.
telnetd/ftpd dont seem to be running - but I see these ports are open
PORT STATE SERVICE
1024/tcp open kdm
1025/tcp filtered NFS-or-IIS
6000/tcp open X11
Rebooted after sitting for 15 min at the blue "Starting the Common Desktop Environment" screen, after reboot it's back to the colorful AIX screen that just has a few log lines as shown in the post above. Something is not letting X11/CDE load, and the only difference is the SCSI RAID card, I'm at a loss where to look next.
572
www.floodgap.com
If it's always halting at "System initialization completed" it doesn't sound like it's executing any of the rc scripts. What does /etc/inittab look like? What rc files are in /etc? (rc.tcpip, rc.local, etc)
2,307
:forehead slap:
Well. turns out if you have a floppy disk in while installing something is written to that disk and then the startup is different due to that (dont know the details are but it was the root of the problem)
I figured it out when I decided to dd /dev/zero my images and rebuild the raid - the disk was still in... and i recall it saying "saving to boot disk" which till now I assumed was the main boot volume hard disk, but was actually the floppy disk. Ejected it and we got the normal start and rc services started.
