Successful compact flash upgrade for PowerBook 3400c
christcc2
12
View attachment successful-compact-flash-upgrade-for-powerbook-3400c-v0-1bfrp9jsd8jf1.webp
I recently picked up this 3400c that for the most part is in excellent condition other than needing a new power adapter, a replacement PRAM battery and maybe some service to the power supply board. (Or a replacement one).
After reading through Jeff Geerling’s restoration post and some posts on 68kmla I decided on an IDE to compact flash adapter and a SanDisk 4GB card.
Both worked immediately and were recognized by HD Setup. I split the card into two partitions - one for System 7.6.1 and the other for more data.
This 3400c came with a 32MB RAM upgrade. I’m going to pickup a larger RAM card in the future.
- https://www.amazon.com/dp/B00S6GIHS2
- https://www.amazon.com/dp/B0007QU6ZQ
Credit to Jeff Geerling and his blog posts and video that helped guide me along.
What isn't shown here is that the power supply board has been finicky - the PRAM battery was leaking and I cleaned that up. I didn't see any bad traces, but corrosion had moved through the battery wiring harness. I soaked that board in alcohol for a day and cleaned it. The caps aren't leaking - but I'm going to recap that board as a next step. I replaced the PRAM battery and relocated it to another part of the enclosure.
It's starting to come together. Great companion to my PowerBook 165c which was my first PowerBook restoration.
MissDlys
J'ai récemment récupéré ce 3400c qui, dans l'ensemble, est en excellent état, mis à part le fait qu'il a besoin d'un nouvel adaptateur secteur, d'une pile PRAM de remplacement et peut-être d'une révision de la carte d'alimentation (ou d'un remplacement).
Après avoir lu l'article de Jeff Geerling sur la restauration et quelques messages sur 68kmla, j'ai opté pour un adaptateur IDE vers Compact Flash et une carte SanDisk de 4 Go.
Les deux ont fonctionné immédiatement et ont été reconnues par le logiciel de configuration du disque dur. J'ai divisé la carte en deux partitions : une pour le système 7.6.1 et l'autre pour des données supplémentaires.
Ce 3400c était livré avec une mise à niveau de la RAM à 32 Mo. Je prévois d'installer une barrette de RAM de plus grande capacité prochainement.
Je tiens à remercier Jeff Geerling pour ses articles de blog et ses vidéos qui m'ont été d'une grande aide.
Ce qui n'est pas visible ici, c'est que la carte d'alimentation était capricieuse : la pile PRAM fuyait et je l'ai nettoyée. Je n'ai pas vu de traces de corrosion, mais celle-ci s'était propagée dans le faisceau de câbles de la pile. J'ai fait tremper la carte dans de l'alcool pendant une journée, puis je l'ai nettoyée. Les condensateurs ne fuient pas, mais je vais les remplacer prochainement. J'ai remis la pile PRAM en place et je l'ai déplacée dans une autre partie du boîtier.
Ça commence à prendre forme. Un excellent complément à mon PowerBook 165c, qui était ma première restauration de PowerBook.
HEY ! Wonderful, I also rebuilt a PB3400c, I'll talk more about in a new post after, could you tell me where do you find a new Pram ? Thanks
