2,184
I have 1 Analog Board that came with the Mac SE @Kai Robinson very graciously sent to me in the past (from the UK), and I also have 3 other Analog Boards that I use with my SE/30 machines. All Analog Boards have been recapped, trace-repaired, and have the same Noctua 60mm fan installed. The SE has a recapped SONY PSU inside, with POT set to max by me. Motherboard is the SE Reloaded board I built myself, with 4MB RAM and WarpSE installed — working perfectly.
I tested all 4 Analog Boards inside my Mac SE (from Kai) last week. All 4 produced a perfect picture on the CRT. But the stock "SE" edition Analog board (Euro edition) shows the highest voltage at the external floppy drive connector, while the other 3 boards showed the exact same "lower" voltage.
Mac SE with Euro edition SE Analog Board (5.16V)
Mac SE with 3 different US edition Analog Boards (5.04V)
I am located in Japan, so AC power into the SONY PSU was 100VAC 60Hz.
Note that the main wiring harness cable connecting the Analog Board to the Motherboard was beefed up by me with 16AWG wire to ensure the smallest voltage drop.
5.16V - 5.04V = 120mV
120mV is a large difference, especially so when you consider that all three Analog Boards from my SE/30 machines showed the same exact 5.04V.
Have any of you have seen such a difference among your own Analog Boards before when tested on the same machine?
Reactions: GreenBar0n
2,184
You are asking about the 74LS38 VCC Pin 14 voltage, but I don't have the EU edition Analog Board currently installed right now to test. Even so, before I do any board swap to perform such a test, note that the voltage levels at the Analog Board are higher than what my Mac-O-Meter shows at the external floppy drive connector. The reason is because there is resistance in the analog board traces, more resistance in my upgraded 16AWG main wiring harness cable, and more resistance in the motherboard traces. So if I remove the current A.B. and swap in the EU edition A.B. and then measure at 74LS38 VCC Pin 14, it very well could be 5.26V or slightly higher.
For everyone else reading this thread, you may be wondering...
Why does this even matter?​
ANWSER: Because, especially on the SE/30, "low voltage on the 5v rail" is a real world issue for many, especially if you have upgrades, and absolutely if you have the untouched stock main wiring harness.
In the past I was getting on order of 4.65V at times on my tricked-out SE/30 machines. Maxing out the voltage POT inside the SONY PSU and beefing up the main wiring harness wires to 16AWG largely eliminated that.
But now that I have discovered a key difference between the EU Analog Board and my 3 US Analog Boards, it would be good to nail down the cause. Why? Because some of you out there use the Baby Face or similar modern PSU which uses Meanwell MODULES that have fixed voltages that cannot be cranked up like you can on the stock SONY PSUs. No need to do that for anything but the 5V rail, but still. It is what it is. And so, if you use a MEANWELL MODULE type modern PSU replacement, you'll get a rock solid 5.0V when measuring at the Analog board, but when you measure at the motherboard like I am in this thread (using a Mac-O-Meter for convenience), you will get lower than 5V, and it could be quite a bit lower if you have a lot of upgrades, and shockingly lower if you've not upgraded your main wiring harness.
So if we can determine what on the US boards are drawing more power than the EU board (which would explain the voltage difference of 5.16V versus 5.04V), maybe something on the Analog Board could be changed to eliminate that voltage drop, thereby giving the user a higher voltage level on the 5V rail, which again is what you want if you have a lot of power hungry upgrades.
GreenBar0n
106
66
East Bay Area, CA
Yes, was curious as to where the voltage increase or lack of resistance is coming from on the EU AB. Without knowing the voltage of the Sony PSU at connector P3 Pin 4/9, being able to follow the +5V rail to the floppy port was of interest. Understood about the add-on cards current requirements and why this is important.
2,184
Curious what the 74LS38 VCC Pin 14 voltage is of the EU board, is it 5.16V there and also the collector of Q2?
Sorry for my delayed response.
On one of my SE/30 Analog Boards (all 3 of which report 5.04V at the FDD connector via Mac-O-Meter), I measured the following tonight:
  • Collector of Q2 is 19.68V.
  • Pin 14 of U1 (74LS38) is 4.878V
Sorry, but I didn't have time to do a board swap to test the SE/30 A.B. (which shows 5.16V on Mac-O-Meter).
GreenBar0n
106
66
East Bay Area, CA
I have (4) Sony CR-44 PSU's here, (3) recapped and (1) stock but barely used. I'll get some voltage readings this weekend from all of them, including the floppy ports, the P3 connector +5V voltages on the AB, readings at 74LS38 VCC Pin 14, connector P4 pin 9 as it exits the AB to the logic board, as well as the Q1 base and Q2 collector, to see if there is any similarity or pattern. All of these PSU's and AB's are still factory set, only the caps were changed.
GreenBar0n
106
66
East Bay Area, CA
Didn't have too much time today to get this going, a really nice older couple I've worked with in the past called me to convert their standard HTML website to Wordpress - I'm an IT Admin and that's not been a regular request this entire past decade :). They're such good people that I was happy to help them out; they gave me a Commodore SX-64 a couple of years ago and a brand new looking SE last year, the same SE that's being tested here today.
Was able to get voltage readings from the floppy ports of (2) SE's and (2) SE/30's.
All of these were measured with their own Sony CR-44 PSU's and AB's, for now, will test the individual boards tomorrow and determine which revision AB's are in each as well.
Only SE #2 has the stock caps, the other three have every board recapped.
SE/30 #1 (took over a year to fix this one)
+12.79V
+5.057V
SE/30 #2
+12.80V
+5.051V
SE #1 M5010 (was given to me nearly 20 years ago) all new caps
+12.73V
+5.02V
SE #2 M5011 (given to me by the couple who's website I redid today) all stock caps
+12.77V
+5.033V
Will get the AB's measured tomorrow, using the same PSU for each and measured at the floppy ports again.
These all got a new 3D printed PRAM battery adapter and CR2032, so had them open already, perfect timing for this experiment.
Reactions: iantm and JDW
2,184
Wow, that’s pretty neat.
I must assume that in all of your machines you are using the stock wiring harness, whereas my harness has been upgraded to 16 gauge wire. Wire thickness has a rather dramatic effect on the voltages you will read at the external floppy drive port.
Another important consideration is that my recent voltage measurements presented in this thread have been made with the small POT inside the Sony PSU set to its maximum setting.
GreenBar0n
106
66
East Bay Area, CA
I'm reading very close to the same voltage you listed above in the floppy ports, you're showing 5.04V and a 5.12V, I'm between 5.05-5.02 in all (4) and with the factory set potentiometer - am running the stock wiring harness for all of them.
I measured 125Vac coming out of my wall socket; I see that you're in Japan and they run about 100Vac there? Are you boosting the mains power in any way to your SE and SE/30's?
It's been a long time since I got my A.A for electronics but I remember the heavier gauge wire being better for passing a higher flow of current, like a larger water pipe can flow more gallons per hour; but I had thought the voltage should be the same unless the current draw is too high for the diameter of the conductor, which then displays resistance in the form of heating up the wire.
I have built a few vintage guitar amplifier clones and those were generally rated to run at 117Vac, so the B+ voltage being higher with 125Vac can affect the sound, making it 'stiffer' and not like they used to sound back then. Without a Variac to bring the mains down to 117Vac, I have to adjust the power tubes bias to get the sound I'm looking for out of them.
I wonder if it would be more helpful to measure the resistance of the logic board's from the +5V input, to the floppy port, and do the same with the analog board, from beginning to end of the +5V rail, to see if the resistance varies. Will give that a try later today, couldn't hurt.
2,184
I normally leave the white vinyl cover on the solder side of the analog board off so that I can more easily measure voltages at the very back of the main connector where the main harness will connect on the flipside of the board. And almost always, that voltage level is going to be higher than what you’re going to measure at the external floppy drive port on the motherboard due to resistivity losses in the main wiring harness and in the motherboard itself. And if you have a lot of upgrades installed, that voltage measured at the external floppy drive connector will be lower still. All of that makes logical sense electrically speaking because it’s basically Ohm’s law, where you’re running all of that power through the main wiring harness and motherboard traces that have a small amount of resistance. But that will affect all four of my analog boards and not simply just one of them.
Even when using 16 gauge wire, there are still resistivity losses because the resistance even in that thicker wire is not absolute zero. But I always find there’s a slight voltage increase, when measuring at the motherboard’s external floppy drive connector, when I use the 16 gauge wire upgraded harnesses.
Due to the thickness of the insulation on the main wiring harness, I always thought the actual copper wire thickness to be 18 gauge, but in fact it’s only 22 gauge. That’s why there’s a pretty good difference when you upgrade your main wiring harness with true 16 gauge copper wire.
I am using straight out of the wall 100 VAC 60 Hz power here in Japan, and the exact voltage is going to vary a bit so it may be 103 V or even 105 V or even as low as maybe 98 V at times.
But despite that lower AC voltage from the wall socket, the fact remains that the voltage measured at the external floppy drive connector on the motherboard is different when I compare my stock SE analog board to my three analog boards that came from my SE/30 machines. And the reason I am currently testing with the Sony power supply’s POT set to Max is because if I don’t set it to Max and then test my 3 SE/30 analog boards, the voltage I measure at the motherboard’s external floppy drive connector will be less than 5 V. I was actually measuring 4.90 V originally, with my SE/30 analog boards installed, and that’s why I decided to boost the voltage inside the Sony power supply to bring those up to 5.04V, but that results in my stock SE analog board measuring 5.16V at the external floppy drive connector using Mac-O-meter.
