I have 1 Analog Board that came with the Mac SE @Kai Robinson very graciously sent to me in the past (from the UK), and I also have 3 other Analog Boards that I use with my SE/30 machines. All Analog Boards have been recapped, trace-repaired, and have the same Noctua 60mm fan installed. The SE has a recapped SONY PSU inside, with POT set to max by me. Motherboard is the SE Reloaded board I built myself, with 4MB RAM and WarpSE installed — working perfectly.
I tested all 4 Analog Boards inside my Mac SE (from Kai) last week. All 4 produced a perfect picture on the CRT. But the stock "SE" edition Analog board (Euro edition) shows the highest voltage at the external floppy drive connector, while the other 3 boards showed the exact same "lower" voltage.
Mac SE with Euro edition SE Analog Board (5.16V)
Mac SE with 3 different US edition Analog Boards (5.04V)
I am located in Japan, so AC power into the SONY PSU was 100VAC 60Hz.
Note that the main wiring harness cable connecting the Analog Board to the Motherboard was beefed up by me with 16AWG wire to ensure the smallest voltage drop.
5.16V - 5.04V = 120mV
120mV is a large difference, especially so when you consider that all three Analog Boards from my SE/30 machines showed the same exact 5.04V.
Have any of you have seen such a difference among your own Analog Boards before when tested on the same machine?
