Arbystpossum
92
59
USA
I replaced mine with a 120Gb drive I got off of EBay, I imagine one of those IDE to SD card solutions could work too. If you want to, you can also use the internal SCSI connection and install a "BlueSCSI" or "SCSI2SD" depending on what you want to try.
493
237
96
Be aware that the Beige G3 can boot only from partitions in the first 8GB of the IDE drive due firmware limitations.
Does that apply to all 4 revisions of the Beige G3 firmware?
Does that apply to Mac OS 9 as well? I've seen Mac OS 9 is able to see partitions beyond 128 GiB.
I know that early versions of Open Firmware (e.g OF 2.4) have bugs related to detecting LBA28 and don't have code for LBA48. I think it's just a software issue, not a problem with the hardware. LBA28 support can be fixed with a simple nvramrc patch.
Only Mac OS X depends on Open Firmware for booting.
Mac OS 9 depends on the 68K toolbox part of the ROM and Mac OS 9 drivers on the disk. I think Mac OS 9 has LBA28 and LBA48 support.
My IDE notes:
Feb 12, 2026
Sunday at 3:10 PM
For maximum safety, using CHS limits (in case LBA isn't working):
The 8 GiB partition should be < 7.87 GiB (partition start + partition size should be ≤ 16383 cylinders x 16 heads x 63 sectors per track = 16514064 blocks = 0x00FBFC10. This is slightly less than LBA24.
The 128 GiB limit is 65535 x 16 x255 = 267382800 blocks = 0x0FEFF010 (actually 127.5 GiB). This is slightly less than LBA28.
Older IDE notes:
Sep 15, 2009
Sep 11, 2016
Mar 6, 2022
Apr 24, 2022
Jun 7, 2022
Jan 24, 2026
Trying with a startech adapter but strange behavior have 128 ssd after installation on (test) partition on 6Gb (only)
Still booted form CD and want to change startup disk to de new one mac hangs - reboot it starts form disk but still if i select startup disk it hangs
2 partitions from 6 Gb and 1 with the rest gives bus error
Just for sure - old noisy HD installed - boot form CD and startup disk is working normal. The startech gives a problem.
speakers
158
99
San Jose, CA
peak-weber.net
Re: 8GB boot restriction...
Hhmm ..4? Beige G3s have OFW versions 2.0f1 or 2.4 and are not updatable (unlike the B&W G3). The 8GB boot restriction applies to both.
Yes. See https://lowendmac.com/1997/beige-power-mac-g3-1997/ and https://lowendmac.com/1998/beige-power-mac-g3-1998/ .. and I can confirm this on my desktop and tower machines. It equally applies to any booter calling OFW to do the loading.
Once booted, classic MacOS (and OSX/Linux/*Unix) can access partitions over 8GB.
I'm not sure about Classic Mac's 128GB limitations on these machines - though I do know that MacOS9 on my B&W G3 gets confused by bigger drives.
Trekintosh
30
14
Yeah my molar despises the startech sata > ide adapter. I tried multiple ROMs, too, an A and a C. It works *okay* with the green no name adapter except once you actually boot it just hangs on the desktop forever. (Using an Intel 60GB SSD) I ended up going with a flashed SATA card courtesy of Xodium.
