The rabbit hole opens and now the heat is on the find that elusive tech note!I'm sure the exact technical reasoning is buried in a tech note somewhere.
@Fizzbinn
Thank you for the links. No scary warning that I could find (yet) about AC Adapters rated for more Amps than the stock Adapters, but the search is still on for that.
You're saying that Apple put current limiting features in the power adapter instead of inside the Mac. You can't use third party power adapters if that's true. You would have to test the adapter to verify how much current you can draw from it. What happens to the adapter when that current limit is exceeded? A fuse would make it inoperable until it is replaced.Actually, you need to go back to the Macintosh Portable to understand. It's not Ohm's Law. The Mac Portable's power system was really a crazy design because if you used another AC Adapter with the same voltage but higher current (even only 1A higher current output), that would fry motherboard components over time!
Because the PB100 design is basically just a Mac Portable in a smaller case, some fear the same bad power design could be used and therefore are wary about using a non-stock AC Adapter (or one that has higher current). It seems that other PowerBooks might be okay, but @Daniel Hansen posted earlier than the PB150 is probably not OK and is like the PB100.
I myself don't really know what will happen if you match a 5A AC Adapter with a PowerBook 165c or 180c, for example. I think we are all afraid to try. But what we do know is that if you use an adapter with too low a current rating (2A rather than 3A for a 180c, for example), the machine won't power on.
This note is almost useless. Watts = Volts x Amps. Which quantity causes the damage? Can you use an adapter that's 19V 1A? 1V 19A?Note: AC adapters producing more than 19 watts can damage the PowerBook 100 and 150.
Actually, you can. I know people who have safely used modern AC Adapters with their Portable but those Adapters match the Apple Adapter in terms of output being 7.5V @1.5A. Voltage and Current output must be the same, and such Adapters do exist. Tolerances of those modern Adapters (as reported to me by others — I've not tried them) seem to be tight enough on the modern adapters such that very slight variation of voltage and current doesn't cause damage. Of course, the issue comes down to how slight, but I guess 100mV and maybe 200mA.You're saying that Apple put current limiting features in the power adapter instead of inside the Mac. You can't use third party power adapters if that's true.
The motherboard burns and heatsinks change color, as @techknight clearly shows in this video (an absolute MUST WATCH):What happens to the adapter when that current limit is exceeded? A fuse would make it inoperable until it is replaced.
I cannot give you an exact answer because I do not know, but I can tell you that both VOLTAGE and CURRENT are likely going to be an issue if either way off the nominal values, just as they are on the Mac Portable. Put 7.5V @ 2.0A into a PowerBook 100 and it works great. Use the same Adapter on a Portable, and you'll see what you saw in TechKnight's video above. (Also see my spreadsheet for specs.) But put 9v @2.0A into a PB100? You're likely going to fry something. Put 7.5V @ 3.0A into a PB100? I'm guessing (haven't tested, so I don't know), that the same thing that happens to a Mac Portable will happen to the PB100; namely, that something will overheat or fry. The Apple Tech Note seems to indicate that to be true.This note is almost useless. Watts = Volts x Amps. Which quantity causes the damage? Can you use an adapter that's 19V 1A? 1V 19A?
