Released — MacDoom for SE/30
MacOfAllTrades
253
254
After watching the two videos by @KennyPowers , I was just wondering if there would be a way to make the background dead space (all four sides, outside the game area) be black rather than white?
I must admit that I've been so busy lately, I've not had time to try it out myself yet, but I've been following this thread and the work done on this game is incredible. Bravo, @MacOfAllTrades !
Making it black would be good — actually - the border *is supposed to be black*! But yes somehow it’s rendering as white on @KennyPowers ’s screen which is very odd.
Similarly strange, I see on your video @KennyPowers that the HUD (ammo/weapons/keys bar) the background is showing up garbled in some way. Very strange.
This is a screenshot of 256 grays mode on my Basilisk II:
Something is def up. I’ve no idea if it’s due to your (sweet sweet) upgrades somehow (??).
KennyPowers
349
380
Could have something to do with those. I also see that 7.5 is listed as the minimum OS version, and like I said in my previous post, I'm running 7.1. Until I cranked the CRT brightness, the game content and the border were all very, very dark...too dark to see much of anything. Other grayscale content looked fine at the more reasonable mid-range brightness setting I usually leave the CRT at.
KennyPowers
349
380
@MacOfAllTrades So I misspoke earlier when I said the border was black for me. It's light gray, even with the CRT brightness at a reasonable level. Here's a video of a complete run at default settings with the system set to 256 grays and the CRT brightness slightly higher than where I usually keep it, but not maxed:
I briefly turned the brightness up and then back down at about 50 seconds into the video. Also, after exiting the game, notice that unobscured parts of the desktop background were set to white and weren't repainted.
I poked through the code and noticed some special paths in i_video_mac.c when Gestalt identifies the machine as an SE/30. I was curious if maybe it didn't like it when g_color_depth != 1 and machine_type == kMacModelSE30...maybe that's a scenario that hadn't been exercised yet? So, I used Wish-I-Were to make the machine report itself as a IIsi...no change in behavior. I also tried hard-coding s_use_copybits to 1, but that was mostly just to see if I could build the project (which I could!). Nothing I tried changed anything.
Again, this is on System 7.1
MacOfAllTrades
253
254
I think someone else ran it on system 7.(0? 1?). I just used 7.5 for my dev setup and stuck the reqs to that. A few sound manager calls that I didn’t confirm were ok pre system 7.5 also but only because when I looked up something I ended up cross checking it to sound manager version that shipped w 7.5 but I would not doubt that it runs fine on 7.0
as for the white background- In color mode the background is pink due to some color palette issue when doom code kicks in. So I wager you’re seeing the grayscale version of this which is a gray. I’m just not sure why I don’t see it in basilisk but not surprised due to basilisk being often unfaithful for an emulator ANd or your unusual setup.
copybits stuff should work fine on se/30 though it was made for newer Mac’s where writing to the memory like in the se/30 was causing problems.
the separate paths for b&w vs 8bit (color or grays) is a bit atrocious. I wanted to protect the performance of the b&w mode above all else and didn’t want it impacting performance just to get color working or for the sake of cleaner code for color so it pretty much gets its own path.
After your posts last week I did get a full screen color mode working based on your interest and it being of logical interest. I stopped short of posting it because it acted slightly different (better to be honest) than the 2x b&w mode. I think I hit git push on the code just never updated the binary. Not sure though… just don’t remember if what I last pushed was the final version of the color 2x. But pull the latest source code and build it (great that you could build!!) and try 2x mode with your grayscale!
MacOfAllTrades
253
254
Just played your latest video. Not news but I still am confused by the HUD artifacts (junky background on the HUD). Did that get any better with copybits? I may have to just acquire the same awesome hardware setup like yours to make sure I solve these problems and have a convenient test bed :p
KennyPowers
349
380
It trying to display color instead of grays might explain why the game content is so dark too. I also run Wolfenstein 3D on this machine, and that game actually switches the mode to 256 colors (have to switch it back in the monitors CP after closing the game). Wolf3D also appears a bit dark in "color" mode. FWIW, here's what the 256 "color" palette looks like in the CP, though you're probably creating your own palette. You can still see that a lot of colors display as similar shades of gray. Maybe Bolle chose that palette because it makes the system UI and things look best in "color" mode, but I don't really know what I'm talking about :)
Edit:
I did just see where you previously said "Yes the color mode and grayscale (same thing, game knows no difference)". I wonder if basilisk cheats at implementing grayscale somehow...maybe it just applies a filter to color mode or something?
I guess I don't know how 256 grays mode works at a fundamental level. Is it a palette of 256 configurable values like 8 bit color mode, or something else? If something else, what algorithm maps colors to grays, and where/when is that conversion applied (in software, hardware?)? I know converting to grayscale by simply averaging the RGB values will result in a darker looking image than using a luminosity-weighted average. But it also looks like there's something palette related happening here too with the artifacts in the status bar.
pfuentes69
382
298
Wow... Wow... WOW!!!
It's been long time since I don't come around I once I do it I find this!
I'm gonna test this ASAP on my SE/30. It has a 030@50MHz accelerator, 32 MB RAM and 32-bit ROM (ROM-inator II)... Hopefully it will work with my config!
Reactions: MacOfAllTrades
MacOfAllTrades
253
254
Edit:
QuickDraw takes care of it in this case. There is literally no different code paths for 256 grays than what’s there for 256 colors. I didn’t even plan for it. It just worked when I got 256 colors working.
But I’ve never been familiar with how Bolle’s card works - heck the fact that you can see 256 colors as an option that “works” on a grayscale screen is interesting news to me.
Here’s an idea — try using 256 grays instead of 256 colors mode to play Doom SE/30. See if that resolves any of the issues.
MacOfAllTrades
253
254
Would love to hear how it goes. You should be able to play it in Hi or Low quality modes with good frame rates which will really make the black and white game look good (compared to QUAD mode quality). Thx for being willing to try it (same thanks for everyone who has given it a whirl)!
KennyPowers
349
380
I have been...all of the videos I've shown are with the system set to 256 grays. 256 "color" mode actually looks worse. I DMed you on discord with part of a convo I had with Bolle about how his card (and the original SE/30 grayscale cards) works.
MacOfAllTrades
253
254
Thanks. Darn thought we had a lead! Not on discord / don’t log on :-(.
would love to see the info you shared maybe a DM here?
Thx!
zigzagjoe
25
Micron cards use a single channel (blue) for the grayscale output. This is fine in grayscale mode as the default grayscale CLUT means you get 256 shades of gray. It falls apart if you start messing with the CLUT and/or switch to color modes. Micron should have special-cased the grayscale mode and forced luminance mapping on all CLUT updates (or did it in hardware), but they didn't, so you get only the blue channel of any CLUT changes. We're also making the assumption that at least 8 bits of data are present in the blue channel.
Either way, it looks poorly. On top of that Micron doesn't by default turn on an appropriate gamma table so all is darker than it ought to be.
Can't speak to Bolle's cards but I addressed both of those issues in the driver for my 30video cards. I flirted with the idea of going and writing a new driver for the original Micron card but doubt that'll ever happen.
As a programmer if you wish to be friendly to grayscale cards you should probably do the luminance mapping yourself any time you would touch the CLUT. My cards don't require this (but won't be hurt by it), and at least the Micron boards will benefit.
Reactions: JDW and KennyPowers
KennyPowers
349
380
This is basically the same thing Bolle told me (I wanted that increased vertical resolution his card offered, but I digress :)). So, MacDoom *could* convert its color palettes to grayscale palettes when loading them from the WAD, and then it wouldn't matter that Micron-derived cards only use the blue channel because all 3 color channels for a shade of gray contain the same value. Do I have that right? Did ChatGPT actually do a good job of breaking down the issue?:
The issue is basically: Doom is choosing colors as if the video card can use full RGB color, but the Micron grayscale card is only looking at one part of each color: the blue value. That makes the image’s brightness wrong.
A normal indexed-color Mac display works roughly like this:
  1. The screen memory does not store full RGB pixels.
  2. Each pixel stores a number, usually 0–255.
  3. That number is used as an index into a CLUT: a Color Look-Up Table.
  4. The CLUT says: “color 37 means RGB value (R, G, B).”
So the screen might store:
pixel value = 37
CLUT[37] = (120, 80, 40)
On a normal color display, that produces a brownish color.
On a proper grayscale display, that RGB color should be converted to a brightness value, often called luminance. For example, green contributes more perceived brightness than blue, so a rough formula is:
brightness = 0.30 * red + 0.59 * green + 0.11 * blue
So (120, 80, 40) should become a medium gray based on the combined perceived brightness of all three channels.
The Micron card apparently does not do that. Instead, it effectively says:
brightness = blue
So for (120, 80, 40), it uses only 40, making the pixel much darker than it should be.
That is what they mean by:
In plain terms: the card is treating the blue component of each palette entry as the grayscale brightness.
This works fine only when the palette is already a grayscale palette, where each entry looks like:
(0, 0, 0)
(1, 1, 1)
(2, 2, 2)
(255, 255, 255)
In that case, red, green, and blue are all equal, so using only blue gives the correct result.
But Doom does not just use a simple gray ramp. Doom uses a custom palette with colors like browns, reds, greens, grays, and dark tints. For example:
brown = (120, 80, 40)
red = (180, 20, 20)
green = (30, 160, 40)
gray = (100, 100, 100)
On the Micron card, those become approximately:
brown -> 40
red -> 20
green -> 40
gray -> 100
So colors that should be visibly different may collapse into similar gray values, and colors with low blue values become much too dark. Doom has a lot of reds, browns, oranges, and dark warm colors, so this would make the image look especially bad.
The second issue is gamma.
Even if the card used the right brightness values, the display may still look too dark unless the driver applies an appropriate gamma correction table. CRT displays do not map numeric pixel values to perceived brightness linearly. A value of 128 is not perceived as “half brightness” unless corrected. The developer is saying the Micron driver does not enable a good gamma table by default, so the whole image is darker than it should be.
So there are two separate problems:
  1. Bad color-to-gray conversion
    The card uses only the blue channel instead of converting RGB to luminance.
  2. Bad or missing gamma correction
    Even the grayscale values it does produce are displayed too dark.
The suggested programmer-side fix is: whenever Doom changes the CLUT, do the grayscale conversion yourself.
Instead of putting Doom’s original color palette into the CLUT like this:
CLUT = (red, green, blue)
you would compute a grayscale value first:
gray = luminance(red, green, blue)
CLUT = (gray, gray, gray)
Then even if the Micron card only reads the blue channel, it still gets the right brightness, because:
blue = gray
This should also be safe on better grayscale cards and on color-capable Macs, because a palette entry with equal red, green, and blue is simply a normal gray color.
In short:
The Micron card expects the palette to already be grayscale. Doom is giving it a color palette. The card only reads the blue part of each color, so many colors turn into the wrong shade of gray. The fix is to convert Doom’s palette entries to grayscale before loading them into the Mac CLUT.
That would help MacDoom, but not other games. However, Bolle told me that his card actually does have the ability to mix all three color channels in hardware instead of just using the blue channel like the original Micron did. There are some solder jumpers you have to reconfigure, and then you can use a separate resistor per color channel to control that channel's contribution to the final shade of gray. He said he never found resistor values that properly mixed the RGB channels and it looked bad in all of his attempts, so he did what the original Micron card did and just used the blue channel, which again...seems perfectly reasonable for a grayscale card for a B/W computer to assume a grayscale palette is being used. However, if I can narrow down the resistor value ranges for those 3 resistors, maybe I could connect up some variable resistors and try to "dial" in the color channel mix to something approximating the luminance method of converting color to grayscale:
Grayscale = 0.299 * R + 0.587 * G + 0.114 * B
May not address gamma issues, but maybe I could get "color" games looking better than they do now?
MacOfAllTrades
253
254
Much appreciate all this work and info from all. It’s been a busy week but fixing grayscale on xceed/ @Bolle cards is my next priority as soon as I get a chance to work on it some more (hopefully this week or worst this weekend).
My gut tells me this is almost certainly nailed down to using the blue channel only on those upgrade grayscale cards. It explains everything pretty neatly but that’s what everyone ever said when they were tinkering or troubleshooting anything lol.
My biggest evidence was a @KennyPowers screenshot of their Monitors control panel where the 256 colors looked like a bunch of tiles which is completely different than what 256 grays’ looks like in the same panel. What I don’t quite get is why using 256 grays mode doesn’t produce visually the same thing 256 grays does elsewhere (Admittedly only tried in Basilisk and in SNOW emulator. I trust snow though). It’s like somehow having the Bolle/Xceed card is activating the game to push colors when I would have expected QuickDraw to be doing the conversion to grays… but I’m not an expert in how the system is handling the color change to gray except that the game doesn’t know the difference so I’m ass u ming QD is handling this (maybe it’s done in hardware and I just don’t know it and since the true Apple hardware handles it differently that would explain it all).
Anyway fairly simple fix conceptually to add a true grayscale layer to the game that will select the gray value explicitly based on the original color channels which ought to make it work. The only downside is I won’t have a fast way to test it myself to the fullest extent (i don’t have an xceed or Bolle card) but I thank folks in advance who will give it a whirl. I can at least test that the gray conversion is good on emulation which honestly ought to carry over because it’ll be guaranteeing that you no longer suffer from the blue channel only symptoms.
MacOfAllTrades
253
254
@KennyPowers — OK try this one (just a link to the .bin file from the repo, unbin it and replace the application you had before).
In the options screen i shoehorned in one more checkbox labeled Xceed / Bolle color palette — it just consolidates all the RGB into the blue value
Let me know if things look more correct — brightness should be way better but let me know if it’s OK. But I’m not sure what is causing your weird HUD background still (example below, from your video earlier)— I haven’t been able to recreate that but it’s not just the xceed blue issue.
Anyway - there’s the new option:!
KennyPowers
349
380
Ok, video of that build (temporarily maxed CRT brightness about 40 seconds in):
As you can see, it's much darker than before...about what you'd expect if two of the three color channels were set to zero:
I then altered the code shown above to set the red and green channels to the same computed luminance value as the blue channel on lines 696 and 697 to make a true grayscale palette. That resulted in the exact same thing as my first video...a darkish game window surrounded by a light gray border. So, as you said, Quickdraw is clearly doing color->grayscale conversion when the system is set to grayscale mode. The code shown above was basically asking Quickdraw to reapply the luminance formula on line 695 to a bunch of blues where red and green were zero, resulting in the super-dark output in the video. When I added back the red and green channels, Quickdraw was then converting grays to grays (essentially a no-op), resulting in the same output in my first video. So maybe this is a gamma correction issue, and that's why the unaltered code looks dark?
We should also try to find some other people to test this on both Bolle's card and ZigZagJoe's to rule out problems with my specific system and make sure the problem is specific to Xceed and/or Xceed clones.
KennyPowers
349
380
I did some more testing of the 1.1.0 build on an '040 IIci with a Radius Thunder 24/GT video card (again running System 7.1), and was able to reproduce the artifacting in the status bar that we're seeing on the grayscale SE/30:
So, maybe that further supports the idea that the darkness problem on the grayscale SE/30 is mostly a gamma correction issue, and the status bar problem has nothing to do with SE/30s or grayscale cards? Also, would probably be a good idea to restore the previous CLUT somehow when exiting the program :)
Since I was already running it on this IIci, I decided to see what happens with the system set to higher color depths. Here's 24bit color...I suspect this is why many period games refuse to run unless the system is set to 8bit color, or switch to 8bit color themselves:
Update: I also tried it on a Color Classic running 7.5.5 and it looks exactly the same as the IIci, status bar artifacts and all. Also tried different WAD files (doom2.wad and tnt.wad), and all have the screwed up status bar.
MacOfAllTrades
253
254
Wow thanks so much for that wealth of info. Very confused about the status bar.
glad you messed with the code on the color channels. That’s what I would have done and suggested. Well I could just add a true grayscale support or at least try using a true grayscale clut. I’m confused why, given Bolle’s description about how grayscale works picking up the blue channel only, this doesn’t work.
I think I have an idea about the status bar maybe. The black and white code adjusts the status bar with a different dithering setting to really jack up the contrast. Maybe that is somehow being done on the color mode status bar too. No idea why I don’t get it in snow or basilisk but it’s probably it.
you could always play with the blue channel there a lot in the code like you did. Multiply it by 2 and see if everything is really twice as bright.
Theres no gamma settings that I’m aware of in color mode. The gamma stuff was added for the b&w dithering algo but you don’t have a need for that in grayscale or color but I could be wrong.
I no longer think QuickDraw is even at play here.
KennyPowers
349
380
It seems pretty clear to me why calculating luminance and then only applying it to the blue channel while zeroing the red and green channels made everything basically black.
The QuickDraw documentation says this:
When Color QuickDraw displays a color on a grayscale screen, it computes the luminance, or intensity of light, of the desired color and uses that value to determine the appropriate gray value to draw
Clearly QuickDraw is doing color->grayscale conversion when the screen is set to grayscale in the Monitors CP because MacDoom always does exactly the same thing whether the screen is set to 8bit color or 8bit grays. We can also assume that QuickDraw is doing this using a similar luminance formula to the one you used:
Now what do you get if R and G are always zero in that formula? A really low (dark) value.
I now suspect my original darkness issue is mostly due to a lack of gamma correction, which @zigzagjoe mentioned the Micron-based cards don't apply. I may experiment with applying some gamma correction to the CLUT that MacDoom is creating and see if that brightens things up a bit :) It was also kinda dark in color on my Color Classic's CRT...
