New Video ROM for SE/30
chrisrueckert
Nov 27, 2022
I followed the instructions found here to program a new video ROM: https://tinkerdifferent.com/threads/this-is-what-a-bad-macintosh-se-30-video-rom-looks-like.1446/
To create a new video ROM, I used a GQ-4x4 to program the AT28C64. Then I compared the original video ROM file with the one on the new AT28C64 with HxD. Both were identical. However, the new video ROM gives me this screen on the SE/30? Any hints what could be wrong?
So silly first question is of course was the machine working with a known good video rom before you burned the new one?
If it works when you put a known working rom in but not when you put your burned copy in then something has gone wrong with your programming (are you sure your video rom bin file is complete and correct?) or there is a problem with the eprom you are trying to use.
I used this eprom when I burned my new video rom:
I basically followed the steps from Will from Caymacs:
Elemenoh
432
418
Bay Area
The video ROM isn't 'giving you' that screen per se. That screen is showing the default state of the video ram. Why were you trying to make a new video ROM in the first place? Was it because you saw this screen? If so, you likely have some broken traces or failed IC(s) near UE8.
chrisrueckert
Yes, it works with the original Apple ROM - not a silly question at all.
I compared the .bin files of both the original ROM and one from the copied one with HxD and both files are the same.
And I confirm that I used the same eprom type as you did.
chrisrueckert
I fried an original ROM on another logic board (with its own issues), hence now I'm trying to recreate one.
chrisrueckert
Regarding Will's video: While I followed his approach, I noticed that writing to my eprom would take a lot longer. It was minutes vs. seconds in his video. Maybe there could be a hint on what's wrong?
