Kensington Turbo Mouse ADB Trackball
François
123
France
Took apart my recently acquired Turbo Mouse 4.0, there is two screws hidden under the label on the bottom, but that’s not all: there is what looks like two patches of a soft material attached to the underside of the label, I guess to clean the rollers:
They have completely broken down with age, as to be expected. What can I use to replace them? It has to be some sort of brush, or dry sponge, but very soft as to not slow down the rollers.
While I was there I lubricated the rollers: they're so much quieter now!
First time I used, and even saw in person one of these big trackballs, I was surprised that the ball isn’t captive, it just sit there!
Reactions: eric and bakkus
Stinkerton18
105
85
Some low/medium-density foam should do the trick. You need something mildly abrasive to help clean them but not scratch/gouge/wear out the rollers.
bakkus
124
91
Thanks! I've been wondering how to disassemble mine.
François
123
France
When you have it open there’s a small screw underneath the little roller:
This little roller is just held by friction, you can remove it by sliding a little flat screwdriver under it. Careful not to send the roller flying across the room (ask me how I know!) :ROFLMAO:
  • Haha
larsovef
Norway
larsove.bandcamp.com
I am in the process of refurbishing one of these. The roller bearings are slow and needs a good cleaning. When I spray some IPA on them they loosen up and feels really good, but as soon as they dry up they’re back to slow and gummy. Anyone here that have had success cleaning and re-greasing the roller bearings?
davewongillies
47
52
CA, USA
Have you tried greasing it with something besides IPA, like an actual grease?
Reactions: larsovef
