491
291
www.floodgap.com
What version of Mac OS are you using?
What version of the Startup Disk control panel?
Post output from DumpNameRegistry. It should show if the ANS comes up as a AAPL,9500 or as a AAPL,ShinerESB. The latter should be the case when Open Firmware detects the internal SCSI (vendor/device ID 1000:0003).
The PowerSurge script fixes a few bugs in Open Firmware 1.0.5. It probably shouldn't be used for the ANS versions of Open Firmware as I've explained in a previous post. I've attached a version which explains some of the patches. It includes some of my own patches for XPostFacto.
I agree it shouldn't be used and it does not seem necessary. This is OS 9.1.
There is nothing in the CDEV's table that matches AAPL,ShinerESB, so that wouldn't match the behaviour nor the Gestalt ID.
Meanwhile, there is a difference in MACE Ethernet between the two ROMs: onboard works with 2.0 and also 1.1.22 but not 1.1.20. The device exists on all three. I cannot find an ndrv or nlib that corresponds to it in 2.0.
What's the issue with ttya? It is a devalias that should exist in Open Firmware and points to the modem port.
The devalias for ttya is /bandit/gc/escc/ch-a
printenv shows that the default input-device and output-device is kbd and screen so something must change them to ttya.
input-device and output-device only affect Open Firmware so it shouldn't be a problem for Mac OS 9.
The default for PowerSurge machines is ttya. The default is set when the PRAM is zapped.
Yes, it's pesent, but it's handled differently. In ANS Open Firmware, a 'ttya' setting is taken literally, so the machine will come up with a black screen. While the system will start, no graphics output will appear on any video card or internal video, including the Open Firmware prompt. The ideal situation is that MacOS not try to change input-device and output-device. It doesn't seem that Startup Disk is doing this, however, because it has no string in either fork for 'ttya' - unless it's doing this some other way.
491
291
www.floodgap.com
My socketed connectors arrived, waiting on the other rom board to make it. The sockets feel good, once this is done, if anyone needs anything tested, i gotcha. (if it is preferable, and if it works good, i can ship it out to whomst ever would make best use of it.)
Tried 1.1.20.1, booted into OF on internal display, setenv bootcommand bye would let me boot, i could hear it booting into mac os, but got no display out of either internal or my rage 128...
It also would crash with my 256k cache card (i do not have another :()(but also it being 256k is probably the issue, but i cannot find a larger one)
So i desoldered the 1.1.20.1 chips, flashed the 2.0 and it boots again. very strange...because 2.0 can display from the 128 completely fine...
Also, if someone needs a production rom, i will happily get rid of mine, i really have no intention on ever installing aix again.
Just remove the 256K cache card. The ROM is not expecting it and it almost certainly won't work properly. That was never a supported configuration.
You could try hard setting output-device to the Open Firmware path for the Rage 128. The path will vary based on where you installed it. Try looking for it with dev / and ls. For example, on my machine with a Twin Turbo in slot 1, the path is /bandit@F2000000/IMS,tt128mbA@D.
I have a Rage Orion somewhere (a Mac-specific Rage 128) I can try to dig out to reproduce what you're seeing, but I don't have it handy. Does your Rage 128 card work in another Mac?
mizerable
31
14
Yeah, was just reporting it didnt like it on the 1.1.20.1 rom, it currently isnt in the system. wish i had a 512k, theyre impossible to find for some reason.
Strange, though, the 2.26NT rom reads it fine, dunno if it actually uses it, but at least doesnt crash.
2.0 obvi doesnt see it, so no crash.
Ill have to try that setting when i get the other rom board, hopefully tomorrow, as i wanted my ans up n running again.
I have not tried the gpu in another mac, although it does work. im currently using it just fine on the 2.0 rom, just didnt output in the 1.1.20.1 rom. (also have not tested in my 2.26NT rom)
also also, i offered up my production rom, but forgot its actually a 2.26NT lol
