Mr. Macintosh
35
Can you insert some quotes from previous posts to remind us what this is about?
EDIT your post, click the [ ] button to toggle off BB code, position the text insertion point in your post where you want to insert a quote, find the old post that you want to quote and click the REPLY button of that post, then edit the quote to include just the relevant part. If you split the quote into multiple parts, then make sure each part begins with a copy of the [QUOTE="Author, post: xxxx, member: yyy"] line and ends with [/QUOTE]
Done, sorry should have added that context. 👍
ClassicHasClass
569
www.floodgap.com
@ClassicHasClass @joevt @Rairii Is this the data you were looking for the Windows NT register dump?
VENEER is loaded at:
image_base = 00050000
The exception occurs almost immediately:
SRR0 = 00050014
SRR1 = 00001071
LR = 00050004
DAR = 18A2D8C5
DSISR = 42000000
Page 4 post 66
No, we have this part. We need the full register dump. Thank you for trying it, though - proves it's not just my hardware, but what ROM did you do this with?
joevt
355
137
@ClassicHasClass you are booting into Mac OS using external SCSI?
Looking at ANS 1.1.20.1 Open Firmware in DingusPPC, there's some differences from 1.0.5 that might be strange. When it creates the 53c94 device, it does a reset-scsi which 1.0.5 does not do.
reset-scsi performs 3 commands:
3:CMD_RESET_BUS
2:CMD_RESET_DEVICE
1:CMD_CLEAR_FIFO
DingusPPC expects a 0:CMD_NOP after 2:CMD_RESET_DEVICE so 53c94 doesn't work.
Since you have a real ANS, can you tell me if this command works?
" scsi/sd@0" select-dev
If it doesn't work, then try this:
dev scsi
: new-reset-scsi
	." doing reset-scsi" cr
	3 cmd! d# 500 ms
	2 cmd!
	0 cmd!
	1 cmd!
' reset-scsi ' new-reset-scsi brpatch
reset-scsi
I've attached a script to list partitions from a Apple Partition Map partitioned disks. Load and use it like this:
unselect-dev
dl \ press return to begin the download
\ then paste the contents of the text file (you won't see the contents because
\ echo is not used during download), then press Control-D to evaluate the contents.
list-partitions scsi/sd@0
  • list-partitions.of.zip
Mr. Macintosh
35
Is this it ? This is the 2.26NT.
Also I was trying to find my serial to USB cable but can't seem to find it. Which one are you using?
r0 = DEADBEEF
r1 = 0004FF00
r2 = 000691B8
r3 = DEADBEEF
r4 = 00050000
r5 = FF809C50
r6 = DEADBEEF
r7 = DEADBEEF
r8 = 18A2D8C5
r9 = DEADBEEF
r10 = DEADBEEF
r11 = DEADBEEF
r12 = DEADBEEF
r13 = DEADBEEF
r14 = DEADBEEF
r15 = DEADBEEF
r16 = DEADBEEF
r17 = DEADBEEF
r18 = DEADBEEF
r19 = DEADBEEF
r20 = DEADBEEF
r21 = DEADBEEF
r22 = DEADBEEF
r23 = DEADBEEF
r24 = DEADBEEF
r25 = DEADBEEF
r26 = DEADBEEF
r27 = DEADBEEF
r28 = DEADBEEF
r29 = DEADBEEF
r30 = DEADBEEF
r31 = DEADBEEF
Special Regs:
IV = 00000300
SRR0 = 00050014
SRR1 = 00001071
CR = 00000000
LR = 00050004
CTR = DEADBEEF
XER = C000BE6F
DAR = 18A2D8C5
DSISR = 42000000
SDR1 = 03FE0000
ClassicHasClass
569
www.floodgap.com
That indeed looks like a full register dump, but what command did you use to generate it? Do you have the full transcript of what you did? I want to make sure we're capturing the right information.
I use a PL-2303 USB-to-serial dongle (an old iConcepts PDA adapter; it works with pretty much anything, even Mac OS 9).
Rairii
r0 = DEADBEEF
r1 = 0004FF00
r2 = 000691B8
r3 = DEADBEEF
r4 = 00050000
r5 = FF809C50
r6 = DEADBEEF
r7 = DEADBEEF
r8 = 18A2D8C5
r9 = DEADBEEF
r10 = DEADBEEF
r11 = DEADBEEF
r12 = DEADBEEF
r13 = DEADBEEF
r14 = DEADBEEF
r15 = DEADBEEF
r16 = DEADBEEF
r17 = DEADBEEF
r18 = DEADBEEF
r19 = DEADBEEF
r20 = DEADBEEF
r21 = DEADBEEF
r22 = DEADBEEF
r23 = DEADBEEF
r24 = DEADBEEF
r25 = DEADBEEF
r26 = DEADBEEF
r27 = DEADBEEF
r28 = DEADBEEF
r29 = DEADBEEF
r30 = DEADBEEF
r31 = DEADBEEF
Special Regs:
IV = 00000300
SRR0 = 00050014
SRR1 = 00001071
CR = 00000000
LR = 00050004
CTR = DEADBEEF
XER = C000BE6F
DAR = 18A2D8C5
DSISR = 42000000
SDR1 = 03FE0000
This would imply .data section either wasn't loaded correctly or part of it got overwritten by something.
Any chance you could dump 0x13000 bytes at 0x50000? I can then compare against what *should* be there. Certainly I have no idea where 0x18A2D8C5 came from.
Mr. Macintosh
35
I'm working on getting both now. But I need to get a batter way to get commands to the ANS.
@ClassicHasClass thanks for sending the info about the iConcepts USB serial adapter. The only thing is, what 8 Pin Male to DB9 Female cable did you use? It would seem simple but it looks like different cables have different pinouts and I'm not sure which one we need for console access?
Seems at a base we need
DE-9 pin 2 (RxD) <-> Mini-DIN-8 pin 3 (TxD−)
DE-9 pin 3 (TxD) <-> Mini-DIN-8 pin 5 (RxD−)
DE-9 pin 5 (GND) <-> Mini-DIN-8 pin 4 (GND)
Mr. Macintosh
35
I'm not sure what the wiring is (I can buzz it out if you really want), but it's just an off-the-shelf Mac serial MiniDIN-8 to DE-9 null modem. There are tons of sellers on eBay.
Thanks for that info, no problem I figured it would be fine but when I looked on amazon, a bunch of the cables had bad reviews saying they were wired wrong. I'll just search for null modem. 👍
Mr. Macintosh
35
Just a quick update on trying out Windows NT with some AI tool assisted help. I was able to patch enough memory to get the VENEER.EXE to boot to this
Open Firmware ARC Interface Version 3.0 (Jul 12 1996 - 18:46:28)
Then that errored out with
Couldn't claim SYSTEM PARAMETER BLOCK
Did some more work with patching memory and got to
Couldn't claim RESTART BLOCK
At this point, too much typing was required to keep going so again, I'll just wait until I can connect to the serial console.
ClassicHasClass
569
www.floodgap.com
@joevt
0 > unselect-dev  ok
0 > dl  ok
0 > list-partitions scsi/sd@0
Device isn't there! unable to open the list-partitions device
 ok
0 > list-partitions scsi/sd@0,0
 ok
0 > see list-partitions
: list-partitions
  bl parse open-dev ?dup if
    to ih (list-partitions)
    else
    " unable to open the list-partitions device" type cr
    then
  ; ok
0 > " scsi/sd@0" select-dev
Device isn't there!can't OPEN device
 ok
0 > dev scsi  ok
0 > dl  ok
0 > ' reset-scsi ' new-reset-scsi brpatch  ok
0 > reset-scsi doing reset-scsi
 ok
 ok
0 > dev scsi  ok
0 > ls
FF8461F0: /sd@0,0
FF846FD8: /st@0,0
 ok
0 > dev sd@0,0  ok
0 > words
load            write           read            seek            close           open
write-blocks    read-blocks     max-transfer    block-size      dma-sync        dma-map-out
dma-map-in      dma-free        dma-alloc       sense-buffer    timed-spin      set-timeout
error?          retry-cmd       set-tid-lun     db-rem          write-10        write-6
read-10         read-6          read-capacity   max-blks        offset-hi       offset-lo
disk-label      deblocker       my-block-size
 ok
0 > " scsi/sd@0,0" select-dev
 ok
ClassicHasClass
569
www.floodgap.com
Change @0 to the SCSI ID of your external drive?
It's been a long day, I should have thought of that.
0 > list-partitions scsi/sd@2,0
 #    Start     Size Name                             Type                             CPU          Sigs 0  1  2  Volume
01 00000001 0000003F Apple                            Apple_partition_map                               PM PM PM
02 00000040 00000036 Macintosh                        Apple_Driver43                   68000            `   . N
03 00000076 0000004A Macintosh                        Apple_Driver43                   68000            `     A
04 000000C0 00000200 Macintosh                        Apple_Driver_IOKit
05 000002C0 00000200 Patch Partition                  Apple_Patches
06 000004C0 003FFB2F untitled                         Apple_HFS                                         LK    BD  Shiner9
07 003FFFEF 00000007 Extra                            Apple_Free
 ok
Oh, and " scsi/sd@2,0" select-dev does work.
ClassicHasClass
569
www.floodgap.com
Ethernet extension is done except for making a nice icon. We no longer need the nvramrc, though @joevt's 0 to my-self did get it working.
Last stop is to extract the SCSI driver and then polish up everything.
joevt
355
137
Thanks for this. Looks like DingusPPC needs some fixes for 53c94.
I think ,0 is for the LUN number? Not needed on most devices since they have a single LUN.
Open Firmware has a show-children for each built-in SCSI controllers.
Use it like this:
\ 53c94 (TNT or ANS)
" scsi" select-dev show-children
\ mesh (TNT) or 53c825@11 (ANS)
" scsi-int" select-dev show-children
53c825@12 (ANS)
" scsi-int2" select-dev show-children
Open Firmware 1.1.20.1 adds simpler commands to do the above:
probe-scsi0
probe-scsi1
probe-scsi2
The command should list multiple LUNs if they exist.
A device that might include multiple LUNs is a CD changer?
trag
406
193
I have seen optical disk juke boxes that used multiple LUNs, but I think it depends on how the manufacturer wanted to configure it. That is, not every disk changer may use multiple LUNs. Some might occupy multiple SCSI IDs.
Rairii
before I got my zuluscsi, the only external scsi drive i had was a panasonic PD drive which also read CDs, where the PD showed up as LUN 0 and the CD showed up as LUN 1.
this is how i discovered that classic mac os doesn't like anything not on LUN 0. luckily i had some media (tried dumping it but most of the sectors had bitrotted after not being touched for 25 years), and reformatting it and throwing a system folder on it did work as a classic mac os boot device!
