campbellashe
59
30
Asheville, NC
Anyone get AppleShare/Appletalk working with a 2MB Macintosh Portable.
I have only 2 MB and I'm running System 7.0.1.
I tried to get System 6.0.8 but I can't get this to work...get System Errors frequently...
I have tried both BlueScsi and ZuluScsi.
I have set the "MacPlus" setting in the .ini file.
I have installed the DaynaPort SCSI/Link.
I can get the PING to work but nothing shows in the Chooser.
I can take the same SD card and put in my SE/30 (much more RAM however) and it works -- shows my shares in Chooser.
Setup:
In "Network" I have chosen the "EtherTalk Alternative".
AppleTalk Version is 58. EtherTalk Version is 2.5.
MacTCP set up and PING works.
The Log files for the BlueSCSI and the ZuluScsi both show connections to my network.
I see the warning on the BlueScsi documentation that says it needs 2.5 MB..... perhaps that is the constraint that I'm running into.... but I have no way to update the RAM (hoping that MacEffects can remedy this in the future).
Thanks for any direction. The purpose is to be able to share files to the portable using my Netatalk Server.
Froggy814
153
Squaw Valley, CA
I would suggest trying to emulate what you are trying to do in SNOW EMU using a mac plus to see if its a ram problem or not. It might not work but its worth a shot. Also I kinda have to use SNOW EMU just to put images or applications on my portable because I think my floppy drive is dead. Even after cleaning.
PL212
59
41
I have the same configuration (2mb) and can't get DaynaPort to work either; I just figured it was the well-documented RAM requirement. Would be nice if those RAM cards returned to production, although I guess there's a sweet spot you want to stay under to avoid a system slowdown.
campbellashe
59
30
Asheville, NC
Anyone know if that RAM design works? is it production? Looks like it is in testing.
As for testing, I have the same .hda that I use in the BlueSCSI that I take from the Mac Portable and move it to my MacPlus (with 4MB) and it easily accesses my AppleTalk shares.... This further supports the memory issue.
Weirdly, there is occasionally a very brief glimpse of the shares in Chooser on the Macintosh Portable; they show up for about 5-10 seconds and then vanish. Can't replicate in any way but does happen sometimes right after boot if I look in the Chooser.
You can spend hours troubleshoot this stuff.... but in the end it looks like it is a total memory issue (as clearly documented... but I had hoped it was not true) .
2,198
Just to let the cat out of the bag…
The reason I tagged @SuperSVGA is because he has built his own RAM cards for the Portable and solved key problems too that nobody else ever has:
His tricks include getting 15MB RAM in the Portable and solving the 26% performance hit you get when installing more than 5MB of RAM.
He is not selling his work yet for various reasons but there are actually a lot of projects out there that don’t get started due to lack of time or difficulty to obtain parts or even due to lack of funds or health issues.
My thinking is that if brilliant creators can do a tie-up with MacEffects or a similar vendor who has experience in manufacturing, the creator could take a paper margin and benefit while also bringing that concept into reality. @techknight did that and it was his design that MacEffects sold with his permission.
campbellashe
59
30
Asheville, NC
daanvdl
17
14
Netherlands
Just put up my next repo for v 2 card; not made yet but might want to look at it for next generation and 4-8MB options.
Great!
Froggy814
153
Squaw Valley, CA
FYI that ram the AS7C4096A-12TCN is quite a lot cheaper on aliexpress and lcsc electronics. I know they might be chinesium but they might be a good alternative to $10 per ic!
