jonschultz
6
10
USA
github.com
Progress report:
I have started to move parts from one of the original boards, since not all parts are in yet, and it seems a safer bet as to start with fresh parts (except for all electrolytic capacitors)
not done yet, but work is in progress!
once it's populated i will run a test to see if the power supplies work, before trying it out inside the color classic. ill keep you all posted!
The board looks great, awesome work!
ArjenCNX
91
115
techknight
124
125
North Carolina
Well, got it all together, and on first power up the 5/12/-5 PSU side doesnt work, ill have to de-bug it to see what is holding it up. ill keep you posted on the progress
The amount of times I can count where I had issues with that PSU id be rich. I can say that I am not surprised, hopefully you iron it out.
Make sure standby voltage is making it to the TDA4605 via the opto circuit from the switchon stage.
Reactions: ArjenCNX
ArjenCNX
91
115
Yeah, you got that right! so the HV supply switchmode is working, the +5 +12V one isnt starting through the power on command from the keyboard, im going to find out why that is, i do have the +5V from that HV switchmode side, and that is supposed to power up and activate the main PSU.
ArjenCNX
91
115
Okay, i have +5 and +12 aswell now, but when powering on, and when it's time to turn on the CRT i can see from my AC power meter it's doing a hickup thing where the power goes from 25 to 35W and back to 25W again. so i may have to measure the CRT PSU under load and do some fine adjustments.
techknight
124
125
North Carolina
Yeah that HV side runs 24/7, thats why those zeners get baked out.
That transformer on the 520/550/575 has a slightly different winding ratio, they knocked that 24V tap down to around 18V and did away with the zener diode. They also bumped up the B+ winding.
ArjenCNX
91
115
Now i got all the voltages dialed in, i got the +5 / +12 / +8 / +24 / +60V / -5 all stable under load, but i still have a voltage drop over the 60V line on power up, and im not sure why that is yet. i also have RL28 getting hot, and that is also un-explained as of now, its a 2R2 1/2W resistor, right behind the Flyback transformer.
ArjenCNX
91
115
still working on this, it seems my 60V is always too high at 80+V , the other voltages are in check, at 8 and 24V. quite strange to me. i have soldered up a new board now, but it is still not working as intended.
jonschultz
6
10
USA
github.com
Sounds almost like it's in high-res mod mode, but I assume that's not really the case. :) Have you looked at pot PP1? I don't think you can actually adjust the nominal B+ all the way up to 80V with PP1 alone, but it might be worth a look.
techknight
124
125
North Carolina
Thats only slightly high but its not too far off. It also needs to be under a load from the flyback producing HV before you can really measure it off.
